The computer/module behind the rear quarter panels
Ok so im nearing the end of my FTO research, ive found the O2 sensor (attached to the engine loom) and found the lambda sensor (attached to the interior loom) now i also found this 1996 Macintosh computer which sits behind the right rear quarter panel, does anyone know what this is? Thanks
Re: The computer/module behind the rear quarter panels
What?
If it's located behind the drivers side rear passenger trim, then it would be the factory central locking remote module.
I doubt that you would have factory central locking remote, so it is a bit useless.
You will find that it has a small wire/aerial coming out of it.
I took mine out because the sub made it rattle.
...and isn't the O2 sensor and the lambada sensor 2 different names for the same thing?
Yes it does have the antenna thank you ever so much, so its going in the bin. Yes they are the same thing with 2 names but in the fto manual im currently reading it says the front one (closest to engine) is the O2 sensor and the rear the lambda sensor
But according to wikipedia you are right.
The other one is the cat temp sensor
bumpak wrote:the masterbater has spoken hahaha
Says the one that got caught doing "The Stranger"PHIL069 wrote:bumpak wrote:the masterbater has spoken hahaha
Daniel2019 wrote:Says the one that got caught doing "The Stranger"PHIL069 wrote:bumpak wrote:the masterbater has spoken hahaha
Desperate times....
Check out the price then se the sales pitch.
