Turbo power figures and 1/4 mile times
- vipfto
Re: Turbo power figures and 1/4 mile times
Worked out at 13.25 quarter. Pretty cool converter but unsure how accurate. Worked it out with track day tyres
would be interested to compare with real run does it take into account reaction and wheel spin or just a perfect run?
Reaction time doesn't matter at a drag strip, the time starts when you leave the line
Yeah not the best visuals or easiest UI, point noted and something for me to work on, cheers mateTechnikhaus wrote:That's quite cool!
UI could do with a bit of work though :p
I've run a few real figures through it and it's not bad.
It's got a bit of factoring in for traction i.e levels of horespower and what tyres are being run but this bit is rough.
If someone knows their actual figures then let me know all your details (car weight if it's stripped, power, tyres, 1/4 mile ET) and I will see where else I can make it a bit more accurate
- aza013
- NSW Coordinator
That's a cool link. The panda works out to run a 13.68 1/4 .
- fraz91
- Hair-do
Tried to run the triton through it from my chipped power figures and came out with 17.99s
Very cool tool though.
Wow, what figures have you got on the panda aza?aza013 wrote:That's a cool link. The panda works out to run a 13.68 1/4 .
Did it factor in the blown charge pipe too?fraz91 wrote:Tried to run the triton through it from my chipped power figures and came out with 17.99s
- aza013
- NSW Coordinator
It's a VR manual, 1100kg 137.2kw @ wheels, track rubber.Rob Furniss wrote:Wow, what figures have you got on the panda aza?aza013 wrote:That's a cool link. The panda works out to run a 13.68 1/4 .
That's some good kw's Aza and the estimate is probably not far off.
Don Griffiths (redgpx username on the UK forum) ran a real 13.8 in his GPX manual which is stripped out a little and runs semi drags, you've got more power than him (he's got 210bhp at the fly = about 128.4kw @ wheels)
- aza013
- NSW Coordinator
Thanks. It's all thanks to a fuel company that will stay unnamed supplying bad fuel. Extra work was put into the engine when it got fixed .
Man, if only that fuel company would shell out for a turbo.aza013 wrote:Thanks. It's all thanks to a fuel company that will stay unnamed supplying bad fuel. Extra work was put into the engine when it got fixed .
Bringing back the old puns.
- aza013
- NSW Coordinator
