BC BR coilover max suspension travel
- bjk
- Totes
Anyone know where I can find, in mm, the maximum suspension travel for the BCs? Thinking it'd be easier than trial and error given how annoying it is to adjust the height.
Re: BC BR coilover max suspension travel
Oh god, here we go again..
- bjk
- Totes
I searched.Bennoz wrote:Oh god, here we go again..
This is for poor Tim's sake.
Sent an email to BC anyway.
I garauntee you wont get the ride height correct first go
Easiest thing to do is measure from the centre of the top plate (underside) to one of the lower bolt holes on a standard shock. Then set your BC's to match.
I counted the rotations on the lower section as I wound it up to match the measurement. Then you just match the rotations on the other 3 to get a level height.
Then if you adjust further at a latter date, do the same thing. Wind up 4 rotations for example (which is about a 10mm height drop) then match on all others.
- bjk
- Totes
Oh, it's not so much the evenness that I'm after (though I think the left rear is a bit higher than the right, might just be the camber or my eyes), but how far it actually travels down over bumps/holes/around corners. i.e. want it to not clip the fender on the tyre without being 4X4 height.
(and so I can fit some 255/40 semi's when my tyres die lelelelel)
That's gonna differ depending on how hard you set the damper adjustment..
- bjk
- Totes
Well, for full soft then, or close enough to it. Cause it's still a daily and the ride improved tenfold when I wound it down from the 25 or so it was at.Bennoz wrote:That's gonna differ depending on how hard you set the damper adjustment..
Set it how you think. Then if its still not right, adjust it. If not correct, adjust again. If not correct, adjust again. If not correct, adjust again.
HTH.
HTH.
- bjk
- Totes
It's probably how it will end up going. Only slightly scratching now, so probably won't take much more height.Daniel2019 wrote:Set it how you think. Then if its still not right, adjust it. If not correct, adjust again. If not correct, adjust again. If not correct, adjust again.
HTH.
- kiz
- SA Coordinator
Tim, you should start charging by the hour not the jobbjk wrote:It's probably how it will end up going. Only slightly scratching now, so probably won't take much more height.Daniel2019 wrote:Set it how you think. Then if its still not right, adjust it. If not correct, adjust again. If not correct, adjust again. If not correct, adjust again.
HTH.
1998 Mitsubishi FTO GPVR AERO
- bjk
- Totes
Maybe I should just bag the fucker.
This. Why hasn't anyone done it lol it shouldn't be to hard.bjk wrote:Maybe I should just bag the fucker.
Gen Y: Doesn't want to adjust suspension - so pays for bags
Gen Y: Can't fix car - buys another
- rock_it
Bennoz wrote:Gen Y: Doesn't want to adjust suspension - so pays for bags
Actually I was looking at baggin Bobby ... But was not sure how well the suspension would hold up when pushed hard.. I still wanted to drive the car, and not just have it as an "all show, no go" ...
- bjk
- Totes
What ever happened to 'measure twice, cut once'. It's not that I don't want to, it's just I want to make it as streamlined as possible.Bennoz wrote:Gen Y: Doesn't want to adjust suspension - so pays for bags
Airlift did a comparison, by no means entirely comprehensive, but gives you an indication. https://vimeo.com/78528697rock_it wrote:Actually I was looking at baggin Bobby ... But was not sure how well the suspension would hold up when pushed hard.. I still wanted to drive the car, and not just have it as an "all show, no go" ...
Don't think anyone makes a kit for us though, and it's all twice as expensive as coils anyway.
- shadowarrior
- Tightarse
Gen Y: Doesn't know how to configure adjustable coil overs on his own, yet buys them anyways [emoji14]
Well played, tightwadshadowarrior wrote:Gen Y: Doesn't know how to configure adjustable coil overs on his own, yet buys them anyways [emoji14]
- bjk
- Totes
They were already on the car.shadowarrior wrote:Gen Y: Doesn't know how to configure adjustable coil overs on his own, yet buys them anyways [emoji14]
