Hi Guys! New FTO owner.
- jumby
Hi Guys,
Just picked up an FTO GPX for $3500. Good deal??? 180,000kms
May need new clutch, seems to rev a bit changing gears like ya riding the clutch what do ya think??
http://www.carsales.com.au/private/deta ... 9007/?Cr=0
- shadowarrior
- Tightarse
Re: Hi Guys! New FTO owner.
Welcome to the club. Looks pretty clean.
Check master and slave cylinders first.
- Scorpionwally8
Looks tidY , welcome to the club
- Strkszone
Yeah, more and more FTO's seem to be going for The sub $4k range so you definitely did quite well considering how clean the car looks. However clutches are quite expensive so of course that means you'll end up spending a bit more, but if you take care of the clutch and transmission, she'll treat you right. Just try to avoid the roof rust and you'll be fine.
- bjk
- Totes
WTTC!
A fellow member FTOwnage is selling a brand new Exedy HD clutch for $300 at the moment.
- jumby
Thanks Guys!
She is very clean, just the clutch issue.
will check master and slave today and let you know the outcome
PIIIICCCCSSSSS......
Welcome to the club
Welcome to the club
- jumby
Def needs a new clutch will post pics tomorrow
- jumby
Soooo....
Getting a new clutch, machined fly wheel, new master and slave cylinders today at the mechanics ATM what would you guys expect 2 pay for that?
Thanks
Thanks
- shadowarrior
- Tightarse
Around 1000 would be awesome. They might push it to 1200. All up the parts cost is less than 500, rest is labour.
- jumby
Cool, Have been quoted $1100 hopefully it stays at that price
- jumby
OK guys.
Have got my new clutch installed but now my speedometer and odometer are not working. Have checked the sensor on the gearbox and its all plugged in OK. Any ideas?
Only asking cos the place where I got clutch done is a pain to get to. Cheers
Left something unplugged.
Yep ^^^
That speedo sensor on the back of the box is what controls that. Checked it's plugged in ok, check there's no cuts or damage to the wiring. I've seen boxes removed & that plug forgotten about *stretch! SNAP*
Also check the earths. There's a small earth line that connects to the top of the box, just under the clutch slave line.
