Starter Dying/Dead
mezje
Starter Dying/Dead
Post by mezje »
Yep, it happened, tis the season I guess if you are on the fb page, where is the best place to get one?
Re: Starter Dying/Dead
mezje wrote:Yep, it happened, tis the season I guess if you are on the fb page, where is the best place to get one?
Depends what you want. I got some off eBay relatively cheap. Can get Reconditioned. Could buy a new OEM one for $1k. :lol:
I have a 2nd hand one
    mezje
    Post by mezje »
    dstocks wrote:I have a 2nd hand one
    Awesome, before I proceed, I think it is the starter as the car takes a while to start, or struggles to start. One time it did not start for a good 10 minutes and just made a faint click when turning it on, after doing it a few times I could smell burning electronics - starter?
    Get a confirmation from someone before grabbing. I do know that if you are getting a faint click, try tapping the starter with a hammer and then try again. That will often fix.
      mezje
      Post by mezje »
      dstocks wrote:Get a confirmation from someone before grabbing. I do know that if you are getting a faint click, try tapping the starter with a hammer and then try again. That will often fix.
      I will grab the voltmeter and run it by Dad again, I'll let you know how it goes.
      Tapping is only a temp solution though. But if tapping fixes it then it usually means the starter is on the way out.
