The Wheel and Tyre Bible
Re: The Wheel and Tyre Bible
Would I be able to get away with 215/50/18 or will I have to drop down to 17? Really I'm after smoother ride and wondering whether they'll fit??
- ZFL45H1
I canfit 215/45/17 on my white FTO so I should be able to get 50 profile yah?
Not with 18's.
- bjk
- Totes
- ZFL45H1
Really I just want a more comfortable ride cause I'm on 215/35/18. I'm willing to get 17 inches
- ZFL45H1
Go 17's then. 18's you will be doing well to get a comfortable ride
- bjk
- Totes
The Wheel and Tyre Thread
*Merged the tyre and wheel thread into here; some examples of what different sizes etc might look like. As per BJK's suggestion to sticky it, hopefully this might save a few "what would it look like/will it fit" questions. (didn't want to sticky another thread, so merge it is) - Yang
So we were rambling on Facebook and decided it might be worth making a thread dedicated to member's wheel and tyre combos. Will attempt to be as comprehensive as possible (depending of course on how many people contribute). A forlorn hope, perhaps, but try to keep the ramble down so the information is easy to access. If a mod could sticky it would also helpful.
Please provide as much information as you can first time! I'll start as a template.
Wheel name: Enkei RPF1
Diameter: 17"
Width: 9.0"
Offset: +22
Tyres: 235/45
Suspension:
Stock shocks
Tein lowered springs (I believe)
-2° rear camber
Body work:
Guard liner removed
All guards rolled
Issues:
Does scrub on the inner wheel well on hard turns. Also clips edges of front and rear fenders on hard cornering/bumps.
With 225/45 tyres and 1.0° rear camber.
Diameter: 17"
Width: 9.0"
Offset: +22
Tyres: 235/45
Suspension:
Stock shocks
-2° rear camber
Body work:
Guard liner removed
All guards rolled
Issues:
Re: The Wheel and Tyre Thread
Wheel name: Rota GeForce
Diameter: 18"
Width: 9.0"
Offset: +30
Tyres: 235/40
Suspension:
Stock shocks
Dobinsons lowered springs
Body work:
Guard liner removed
Rear guards rolled
Issues:
Diameter: 18"
Width: 9.0"
Offset: +30
Tyres: 235/40
Suspension:
Stock shocks
Body work:
Guard liner removed
Rear guards rolled
Issues:
Wheel name: Arays
Diameter: 17"
Width: 7.5"
Offset: +38
Tyres: 205/40 Federal 595-SS
Suspension:
KYB shocks
Pointlessly low Lovells
Body work:
sh*t all round!
Issues:
Harsh ride due to low profile
Too much hecticness
Attracts too many hot sluts
See my DIY thread for pics, will link when I get my PC back.
Diameter: 17"
Width: 7.5"
Offset: +38
Suspension:
KYB shocks
Body work:
sh*t all round!
Issues:
Too much hecticness
Wheel name: BBS RG-R
Diameter: 17"
Width: 8"
Offset: +32
Tyres: Federal 595 RS-R 235/40
Suspension:
BC BR Gold Coilovers
-1.5 Camber all round
Body work: None
Issues: None
Next two photos are courtesy of Technikhaus
Diameter: 17"
Width: 8"
Offset: +32
Suspension:
Body work: None
Issues: None
- Res
#notevenFTObuthas6a12
Diameter: 16"
Width: 8"
Offset: +38F/+32R
stud pattern: 4x100
Tyres: KU36 215/45/16r
Suspension:
0*camber allround (need 1.5* though to stop minor scrub)
Body work: all guards rolled (no pumping)
Issues: minor scrub, as said needs approx 1.5* camber and it'll be sweet
Diameter: 16"
Width: 8"
Offset: +38F/+32R
stud pattern: 4x100
Suspension:
Wheel name: super advan racing
Diameter: 17"
Width: 8.5
Offset: +35
Tyres: 235/45/17
Suspension:
KYB shocks
SSL king springs
Adjustable toe & camber arms
Body work:
Guard liners removed
Issues:
None.
Diameter: 17"
Width: 8.5
Offset: +35
Tyres: 235/45/17
Suspension:
KYB shocks
SSL king springs
Body work:
Issues:
None.
- BorepYano
Came across this article, it's probably the easiest thing I've read explaining what you can and can not do; so I thought I'd park it here.
http://www.drive.com.au/motor-news/fitt ... 143ve.html
Diameter: 17"
Width: 8" front
9" back
Offset: +45
Tyres: 235/40/17
Suspension:
Tien coilovers
Body work:
Width: 8" front
9" back
Offset: +45
Tyres: 235/40/17
Suspension:
Tien coilovers
Body work:
- image.jpg (103.94 KiB) Viewed 17620 times
- image.jpg (94.72 KiB) Viewed 17620 times
- image.jpg (126.6 KiB) Viewed 17620 times
- image.jpg (90.44 KiB) Viewed 17620 times
Wheel name: Rota Grid
Diameter: 18"
Width: 10"
Offset: +15
Tyres: 225/40/18
Suspension:
Coilovers
Body work:
Guard liners removed & rolled guards
Issues:
None
Diameter: 18"
Width: 10"
Offset: +15
Tyres: 225/40/18
Suspension:
Coilovers
Body work:
Issues:
None
- image.jpg (118.5 KiB) Viewed 17620 times
- image.jpg (105.92 KiB) Viewed 17620 times
- image.jpg (443.61 KiB) Viewed 17620 times
- bjk
- Totes
Wheel name: Enkei Evo VII stocks
Diameter: 17"
Width: 8.0"
Offset: +38
Tyres: 235/45, 245/40
Suspension:
BC BR coilovers
Offset castor bushes
Body work:
Guard liner removed
All guards rolled
Arch seam cut/welded
Issues:
To be seen
Diameter: 17"
Width: 8.0"
Offset: +38
Suspension:
BC BR coilovers
Body work:
Guard liner removed
All guards rolled
Issues:
To be seen
