Changed stepper motor, now won't start
So car has been unhappy. Sounds rough, idle will hunt between 600-800 after a cold start, has been stalling when coming to a stop, or the revs drop to 500rpm before recovering.
Kiz has a spare black stepper, so I pulled off mine and put it on, and now the car will turn over, rev up and then it drops off and dies. Halp?
mezje
Re: Changed stepper motor, now won't start
Post by mezje »
Have you reconnected all the plugs/looked at plugs you may have disconnected?
Is it in the correct way with the o-ring?
Let it relearn, it'll take ages some times
Only disconnected the one plug. Mike thought it might have been a missing o-ring but there was one there, just checked.
So I should just take it out for a drive again like after battery was disconnected?
Fixed, huzzah. Did need a bit of a drive. Nowhere near as long as for battery. Backed it out of the driveway and down the street and it was already not stalling but took it out for a half hour or so for good measure.
evo-gsr
Post by evo-gsr »
Typical slow learning Mitsubishi!
evo-gsr wrote:Typical slow learning bjk!
This.
evo-gsr
Post by evo-gsr »
Lol.
