The Suspension Thread
- d_dan
Re: The Suspension Thread
So we've a lot of beefy high powered front wheel drives here (or had over the years) this can lead to excess oversteer what have you done to combat this?
Additionally has anyone added toe in on the rear to create slight understeer to counteract the oversteer or what other solutions have you come up with
Do you need a tissue for your issue....slippercream wrote: ↑Mon Apr 19, 2021 4:21 pm Just... wow.
Forget I even asked. For a topic that wasn't answered enough in a timely fashion... don't worry about it.
Nice community.
- getonit
Usually they just man up and floor it.d_dan wrote: ↑Thu Apr 22, 2021 1:10 am So we've a lot of beefy high powered front wheel drives here (or had over the years) this can lead to excess oversteer what have you done to combat this?
Mine could not pull a greased stick out of a dogs arse....but it does handle very well. You need to suck it and see.
Someone elses set up may not be good for you.
- d_dan
Is that a traction due to high power issue or saying that the car has no power?
I don't find flooring it really fixes any problem when your sliding off the far side of the track but I do recognise this is something I can personally improve with better weight transfer and better control of speed into and out of corners
- bjk
- Totes
I don't really have anything insightful to add here, but the question has been bugging me regardless. From what I can find, pretty much any oversteer in a FWD car is a result of the driver, so I'm not sure where the "more power = excess oversteer" equation is coming from, unless you're confusing either torque-steer or lift-off oversteer with power oversteer in a RWD.
Factory alignments specs already call for 3mm of toe in on the rear.
- getonit
I gave the super polesmoker mobile a hiding up the mountain after bonfire. I found the limits on one corner and it was basically like a four wheel drift. I would have expected mad understeer.bjk wrote: ↑Sat May 01, 2021 8:20 pm I don't really have anything insightful to add here, but the question has been bugging me regardless. From what I can find, pretty much any oversteer in a FWD car is a result of the driver, so I'm not sure where the "more power = excess oversteer" equation is coming from, unless you're confusing either torque-steer or lift-off oversteer with power oversteer in a RWD.
- bjk
- Totes
Yeah if I did that I'd end up as a mural on a canyon face was surprised enough I kept it on track at The Bend, more good luck than good managementgetonit wrote: ↑Sun May 02, 2021 11:49 amI gave the super polesmoker mobile a hiding up the mountain after bonfire. I found the limits on one corner and it was basically like a four wheel drift. I would have expected mad understeer.bjk wrote: ↑Sat May 01, 2021 8:20 pm I don't really have anything insightful to add here, but the question has been bugging me regardless. From what I can find, pretty much any oversteer in a FWD car is a result of the driver, so I'm not sure where the "more power = excess oversteer" equation is coming from, unless you're confusing either torque-steer or lift-off oversteer with power oversteer in a RWD.
- getonit
[/quote]
I was full tilt with all my 99kw lol, so yeah you probably would have. Was surprised how predictable it felt.
[/quote]
Posting this here because I f**ken struggled to find it earlier.
If anyone cares, the Bilstein shock part numbers for FTOs
- FRONT LEFT BILSTEIN before - GAS SHOCK ABSORBER - 22-046819
- FRONT RIGHT BILSTEIN before - GAS SHOCK ABSORBER - 22-046802
- REAR BILSTEIN before - GAS SHOCK ABSORBER - 19-061283
- bjk
- Totes
Forum? What's a forum??Bennoz wrote: ↑Tue Sep 21, 2021 11:09 am Posting this here because I f**ken struggled to find it earlier.
What search button?bjk wrote: ↑Tue Sep 21, 2021 5:28 pmForum? What's a forum??Bennoz wrote: ↑Tue Sep 21, 2021 11:09 am Posting this here because I f**ken struggled to find it earlier.
