fto clutch?, why is it so expensive?
AwesomeAsian
Post by AwesomeAsian »
iv asked everywhere and the average price to get my clutch replaced is 2000-2500
thats bs, i cant afford this no more :(
anyone know of cheaper in qld?
d_stroy_r
Post by d_stroy_r »
$2000. NO WAY.
Get a excedy or rpw clutch, they retail just over $500 and get a mechanic to put it in. $1000 max for everything!
RALLiART_FTO
Post by RALLiART_FTO »
$2000!!..
i went to brake pro n got a quote all added up to $726 for everything installed!
dis includes the following:
R1221N CLUTCH KIT = $287.27
GEAR OIL = $18.18
SPIGOT BEARING = $13.64
Labour = $340.91
TOTAL incl GST = $726.00
Rocco
Post by Rocco »
Did u hear that???listen close...kinda like a tearing sound...cause that the sound of u getting ripped!
FTO-279
lol and we dont want to be sleeping on our fronts tonight!
Yeah, I had mine done a while back, was a bit over $700 as well... and that included a 750kg pressure plate too!
poster
Post by poster »
how about heavy duty/or sports clutch once......anyone use them on fto ?
expensive ?
AwesomeAsian
far out
thanks for that you guys,
i was thinking 700-800 max, when ultra tune told me min is 2000 i didnt believe em, but when i rang 2-3 other places they all told me min 2000 so i just about gave up. no one wants to touch em because the labor is very difficult apparently
thanks all :)
FtoSam
Post by FtoSam »
Does anyone know if it is that difficult to do an fto clutch?
I need a new one and my step-dad has done my last few cars... he's pretty good. but never worked on fto.could he do it with a car manual?
Its either get a standard clutch and mechanic or heavy duty clutch and step dad (stepdad+a carton)....
Once you figure out how to get the g'box out past the cross member its pretty straight forward :wink:
FtoSam
Post by FtoSam »
means absolutely nothing to me... Im guessing that either the crossmember has to be removed (Is it possible?) or the engine removed?
There are only 4 mounts holding the motor in, the gearbox is one, the cross member holds 2. So if you undo both the last remaining mount aint gonna hold on that long. Its best done on a hoist with creative engine stand work.
If your stepdad has done a few on the grass out front before, I'd say he'd be able to do this one. He just needs to be able to get the car high enough to drop the box out from under.
