DIY: Changing lower engine mounts
Re: DIY: Changing lower engine mounts
Sahin wrote:The mount casings are the same, so it doesn't matter what ones you use but yes I suggest you buy new manual inserts and yes they are the ones on the cross member.
Thanks mate :D
vanadinite
Post by vanadinite »
So are the evo mounts the same? Which evo BTW?
Changed my side mounts today and confirm the evo ones do fit. They are definitely stiffer but idle quality has actually improved for me.
vanadinite
which ones? all of them or which?
vanadinite wrote:which ones? all of them or which?
Ask a couple more times and u should get a answer soon enough :lol:
vanadinite
yeah lol, everyones got half answers
Ok ive answered this question about ten times and this is what you do.
All FTO's have stuffed side mounts. I was thirst to change mine few years back. What happens is the mounts sag causing your engine to sit lower than what it should and from this rip your front and rear mounts to shreads. That's why the smaller rear always look like sh*t when you remove it.
A good test is your bell housing bolt sit about 10mm above your center member. If your mounts are stuffed the bolts almost touch the center member. Sometimes you will notice scratch marks from the bolts running on it.
The reason people are going stiff front and rear mounts is because their side mounts are stuffed and using a stiffer mount gives the mount more durability which is a half arsed fix.
Fick your side mounts and your front rear mounts wont need extra enforcement as it will not be resting on the mounts hence no damage.
My mounts were stuffed years ago and I will be very surprise any of except the ones who have replaced them have good mounts.
Change them and you will be shocked how better your car will feel like driving it.
Its 140 for the bushes on the side and about 140 for the front and rear mounts with bracket included.
Do what I said and you will thank me later.
+1 - All of them. Learnt that the hard way (or soft way if you will)
vanadinite
Can you link me to these mounts,I am prepared to do them all i just need to know what SPECIFIC car they are from in a straight answer. You may have said it earlier but i wasn't here unfortunately.
Cheers mate.
vanadinite wrote:Can you link me to these mounts,I am prepared to do them all i just need to know what SPECIFIC car they are from in a straight answer. You may have said it earlier but i wasn't here unfortunately.
Cheers mate.
Which ones, lower or upper or both?
vanadinite
the two ont the cross memeber ones and the other 2 that hold the gearbox and engine respectivly. Basically which ones should i replace to be better off in the long run.
Bennoz wrote:+1 - All of them. Learnt that the hard way (or soft way if you will)
My typing sucks when using my phone!
vanadinite wrote:the two ont the cross memeber ones and the other 2 that hold the gearbox and engine respectivly. Basically which ones should i replace to be better off in the long run.
All 4.
vanadinite
Can you link me to them payaya? This maybe a stupid request but i have NO idea what mounts your talking about, are they from an evo? lancer? a mack truck... i dont know. I need specifics so i can go get them. I need all 4 i know that but i need a link to them or where i can find them, that would be great if it not to time consuming for you.
I need an answer like "you need the mounts off of a mitsusbishi evo 3 and here is a link to where you can get them" or something along those lines
Thanks again
Lol spoon feed
Hahahahaha noone tell him
vanadinite
vanadinite wrote:Image
just do a search mayyyte
Jokes bro they used to sell hardened at meek but apparently they ran out
If u want stock ones I reckon just amayama them
silverGPX wrote:Jokes bro they used to sell hardened at meek but apparently they ran out
" hey guys at meek can I have some hardened engine mounts? Yeah mad cheers"
