I want some more?Daniel2019 wrote:Please, sir.
EOI - Mini DIY gearbox day
Re: EOI - Mini DIY gearbox day
Can you give the outside of it a good degrease before the day? Speeds things up when I'm not constantly wiping sh*t cleanDaniel2019 wrote:Please, sir.
Aye, although it's pretty clean as is, been sitting under a blanket for months. Want me to do inside flywheel housing and such?
Yeah toby, just wash it with waterDaniel2019 wrote:Aye, although it's pretty clean as is, been sitting under a blanket for months. Want me to do inside flywheel housing and such?
- Supplanter
That's better.Sahin wrote:Yeah toby, just wash it with vinegarDaniel2019 wrote:Aye, although it's pretty clean as is, been sitting under a blanket for months. Want me to do inside flywheel housing and such?
- Lawso
- Penis Fingers
what time you going to start? I have to work out the train time tables...
10am I think. Will need a good 4 hours to do the job.
Lawso I can drive you...
That was a very subtle way of asking Daniel for a lift lolLawso wrote:what time you going to start? I have to work out the train time tables...
Lawl.Sahin wrote:That was a very subtle way of asking Daniel for a lift lolLawso wrote:what time you going to start? I have to work out the train time tables...
So when you dropping around to mine for the gear.Daniel2019 wrote:Lawso I can drive you...
- Lawso
- Penis Fingers
LAWL! this ^Astron_Boy wrote:Lawl.Sahin wrote:That was a very subtle way of asking Daniel for a lift lolLawso wrote:what time you going to start? I have to work out the train time tables...
Are you and Ben in a similar direction?Astron_Boy wrote:So when you dropping around to mine for the gear.
If gearbox day is starting at about 10am can probably swing around yours beforehand.
That, or, drop gearbox off at Bens then duck out to yours and go back.
Either or.
I'm not near Bens no.Daniel2019 wrote:Are you and Ben in a similar direction?Astron_Boy wrote:So when you dropping around to mine for the gear.
Either or.
Same direction..... maybe, depends on direction of travel.
I probably won't be at mine until 9, unsure of the afternoon as yet, depends when we finish the gearbox swap I'm doing.
Just sms me.
P.S. if you collect on Saturday, can Craig collect from you on Sunday, or whenever he is good to collect from you, given you are closer for him.
Unsure about Craig collecting Sunday, would have to look at my roster but if not, can drop to his Saturday arvo/night most likely.
Where exactly are you located?
< 1 hour from ben's?
- rock_it
If you went to pick up from Astron, you would have to go from your house to Drummoyne, then towards Ryde, Homebush and down the motorway to Ben's ...Daniel2019 wrote:Unsure about Craig collecting Sunday, would have to look at my roster but if not, can drop to his Saturday arvo/night most likely.
- Lawso
- Penis Fingers
- SchumieFan
PHIL069 wrote:Daniel2019 wrote:Aye, although it's pretty clean as is, been sitting under a blanket for months. Want me to do inside flywheel housing and such?@ flywheel
