The Suspension Thread
- funkysmurf
Hey homies,
I have a question for the experts. I have to get new suspension (long story), and I decided on the Tein SS kit. I ordered it and was also going to order the edfc controller kit. While I was on the phone I mentioned that I read (I think around this place) that it won't fit into an FTO. The dude I spoke to said he'll call me back to confirm whether this is the case. Thing is he didn't call back (but did take a $1K deposit).
Can any of you confirm whether this gizmo can be used in an FTO? I tried Tein's vehicle compatibility chart but it doesn't work.
- Grue
I really wanted the EDFC as well, but alas the front servo motors will not fit. They hit the bonnet as the tops of the front struts are the highest part under the bonnet. The rears would fit thou.funkysmurf wrote:Hey homies,
Grue - the springs fit as they are pictured. You can only put them in the one way - the front shocks have a pressed steel base that fits the bottom of that big spring (ie with the one leg of the spring sitting down like that) and the rears have a big plastic cap that sits on the top - it only fits on the smaller dimetre end.
- Grue
- funkysmurf
- funkysmurf
- funkysmurf
Right. So they installed the coilover kit today. Had to go to work soon after and on my way there I nearly suffered kidney failure and I'm sure I'm about 2" shorter with a sore arse. It's too damn bouncy and I adjusted the damper setting to softest all around when I pulled over.
Is there anything I can do to make the car more comfortable to drive? Earlier I read on a web site that the spring rate on these is set at 4.7 front and 4.9 rear. In actual fact it is 8.7 front and 8.9 back.
Ideas?
Ideas?
- mr-charisma
Sounds like a case of too harsh rather than too bouncy..?funkysmurf wrote:Right. So they installed the coilover kit today. Had to go to work soon after and on my way there I nearly suffered kidney failure and I'm sure I'm about 2" shorter with a sore arse. It's too damn bouncy and I adjusted the damper setting to softest all around when I pulled over.
Ideas?
Can only recommend that you drive on flat / smooth roads
- SG
Tein SS was designed for Australia.... all Tein SS models for the country they go to are supposed to be set up for those sorts of conditions......
they are 5kg front/4kg rear for aus.....
i wouldnt set the shocks too soft, on the highway if you need to swerve and you have a high spring rate you could lose control, i reckon... ive tryed swerving a little at 100kph with full soft/off dampers (5/4k springs) and theres no absorption of the energy.... feels like a scandanavian flick in the waiting
are you going to do any motorsport funksmurf?
- funkysmurf
Hey guys. As suggested, I will try to find a place to re-valve them to around 4-5kg.
The idea was to have a bit of a dig around a circuit every now and then. After I was done there I'd get the settings back to road use and I was going to be a happy rabbit.
I actually like the way it is on smooth roads and it's a great feeling swinging into a corner, but as soon as you get a bad patch of road (which is almost everywhere I've driven so far), you get shaken worse than by a British nanny .
The only practical thing about it is that I can prepare my protein shake after I'm done at the gym and by the time I'd get home it would be smooth as. No more takeaway mocha and driving though.
- Grue
The rear Suspension Arm... same for GR and GPX?
Replacing that large bush on it's end and discovered one of mines bent
- khunjeng
even 4-5kg is gona be hard as a rock in the FTO IMO. I have king springs in my skyline 175lb/" / 3.1kg/mm front and 185lb/" / 3.2kg/mm back. They are not the greatest for daily road driving.. Its not that bad though but 2 is def. a much nicer ride.funkysmurf wrote:Hey guys. As suggested, I will try to find a place to re-valve them to around 4-5kg.
- mr-charisma
Ben, in your first post, you mentioned;
I'm finding that my car is sliding out a little on the front tyres when taking a corner at speed & has been doing it for a while now .. I would have to say its understeering .. but it's not the kind've understeer that will get me into any sort of trouble, it's still very controllable - so I can slide around a corner & countersteer for a seemless recovery or if I enter a corner faster, brake harder just before I turn in & shift more weight to the front I can stop it from happening as much as well..
As much fun as it is sliding around corners, it still bothers me a bit & want to stop it from happening altogether if I can.. just doesn't feel right for my FTO to do it.. & it feels like if I was to try to take a corner too fast I'd end up just sliding off the road completely..
As soon as I have some disposable cash laying around I will be taking my car into Fulcrum & getting some lowered springs put on & unless I end up just doing it myself, upgrading the rear sway bar & rear droplinks with some whiteline gear & wait & see how my car is running before I put in a new front sway bar..
Just wondering how I would be able to find out what amount of camber, castor & toe settings I have got on my car.. & how I would go about adjusting it?All dialled in with 2 degrees negative camber, 1.5 degrees positive castor & 0.75 degrees toe in. The camber is probably a little high for street driving & I'll end up wearing the inside edges of the tyres, but I dont care. The tyres are almost gone anyway & the turn in & stability through corners is superb... looks hot too Razz
- RallyMad
