UAS Cold Air Take - Group Buy
- KingJames
- RallyMad
Cheers Bennoz. Got mine. Great work as per normal. Thanks so much for taking your time to get this sorted for us and the overnight delivery was really nice as well. Cheers mate.
I'm looking around for some fitted kit pics at the moment. If I can find Smorison's orginal write up I hope the pics are still up. If not can someone else supply some pics of how theirs is fitted. I'm sure it's not real hard but just looking at the kit I've got no idea what to do with the 3rd hose clamp or how to mount the filter. Any suggestions?
- Taeivon_Rep
Hours of fun spent today putting it all together its a pain in the u know what to get on properly!! Battery is slimline but still too big i've managed to get it on but on the way home throttle body end popped off since pipe ain't cut properly (diy cutting to follow) but main thing is its on!!!RallyMad wrote:Cheers Bennoz. Got mine. Great work as per normal. Thanks so much for taking your time to get this sorted for us and the overnight delivery was really nice as well. Cheers mate.
Starting on bottom half of intake tonight (100mm drainpiping
- aza013
- NSW Coordinator
if you are saying that with a slimline battery then I am going to have a lot of fun as I have a battery that is 5mm smaller than a truck batteryTaeivon_Rep wrote: Battery is slimline but still too big i've managed to get it on but on the way home throttle body end popped off since pipe ain't cut properly (diy cutting to follow) but main thing is its on!!!
Starting on bottom half of intake tonight (100mm drainpiping)
- RallyMad
found mine really annoying but not difficult.KingJames wrote:Really so its quite difficult to put on???
See here for details:
http://www.ftoaustralia.com/modules.php ... ic&t=16357
- Taeivon_Rep
wow then your stuffed. Battery relocation anyone?aza013 wrote:if you are saying that with a slimline battery then I am going to have a lot of fun as I have a battery that is 5mm smaller than a truck batteryTaeivon_Rep wrote: Battery is slimline but still too big i've managed to get it on but on the way home throttle body end popped off since pipe ain't cut properly (diy cutting to follow) but main thing is its on!!!
- xSlurpee
Now we need to put the box in & use some bracing on the filter.xSlurpee wrote:use the battery to squash the pipe in place(no really my unifilter and pipe DID NOT NUDGE)
now that i put in small battery my unifilter shakes heaps and pipe doesnt feel secure.![]()
*dam i didnt get time to give my fto a thrashing after resetting ecu*
- kizl
Re: UAS Cold Air Take - Group Buy
I THINK THERE SHOULD BE ANOTHER GROUP BUY!
I called and asked the place they need like 8minimum
1.NO1DEVIL (Confirmed)
It's not going to happen again
- spetz
What would be the price for 8 minimum?
He said he'll see what see can do for he said he could do cheaper then 395
SAHIN ILL PROVE YOU WRONG!!!
Ive got money for about 6 of them - need about 4 confirmations and ill just put the order through and wait for people to buy it off me when they can :S think thats not a bad idea?
