As long as you have the right tools for itAstron_Boy wrote:Can even do spark plugs without doing the tappets, spark plugs are a synch.
Plenty of them will be standing around on the dayaza013 wrote:As long as you have the right tools for itAstron_Boy wrote:Can even do spark plugs without doing the tappets, spark plugs are a synch.
I have a set of droplinks .. Cost me about $100+ ... Will sell em on the day if need be..Bennoz wrote:Sounds like we may just have to do the swaybar then. Do you have droplinks for it? Because you need them to connect it.
And I think I got confused by some chingrish in there "change suspension spring".... I thought it was only 1. Doing all 4 is about 2 hours worth of work...
Given that, yes,Bennoz wrote:Plenty of them will be standing around on the dayaza013 wrote:As long as you have the right tools for itAstron_Boy wrote:Can even do spark plugs without doing the tappets, spark plugs are a synch.
are they for front and backs or just fronts?rock_it wrote:I have a set of droplinks .. Cost me about $100+ ... Will sell em on the day if need be..Bennoz wrote:Sounds like we may just have to do the swaybar then. Do you have droplinks for it? Because you need them to connect it.
Hey yeah, that would be good. I've only go the one setShane001 wrote:Ben, do you need another set of chassis stands?
Just bring em.Shane001 wrote:Ben, do you need another set of chassis stands?
hey mate.. i may buy this off you as i think the cause of the annoying squeeking from my rear is the droplink..Shane001 wrote:I've got a set of rear drop links from Camskill, standard version. $40 if anyone needs em. Also got a full set of KYB Climb Gear shocks & version R front strut bar. I'll post info in the for sale section
oh, me too.lawsochap wrote:PM your address bennoz?
