Half cut Parts free, everything will be dumped. Pick up only
FTO430
Post by FTO430 »
can i get the slidey thing inside the tip gear stick rail. i dont know what its called.
FTO430
Post by FTO430 »
oh, and does the clock have the little plastic thing that you wind it to change the time, mine never came with one.
overboostin007
half cut
Post by overboostin007 »
Is it the plastic strip that covers the inside of the shifter and moves with it when shifter changes positions?
overboostin007
half cut
cb stepper motor and alternator is available. pm for price
FTO430
Post by FTO430 »
yep, thats it
overboostin007
Shifter plastic slide
Ok $15 plus postage.
FTO430
Post by FTO430 »
deal, and do you have that little clock winder?
onnzo
Post by onnzo »
Are you parting out the rear engine mount?
Mike
overboostin007
engine mounts
Is that the one on the gearbox or the ones below the gearbox from under the car. All mounts are for sale
onnzo
Post by onnzo »
The one on the engine crossmember that runs parallel with the side of the car, closest to the firewall. Any idea what condition it is in?
I will probably need some suspension parts, I'll let you know what I need when I hear back from my mechanic tomorrow :(
overboostin007
suspension
Ok struts are available. Along with brakes and rotors.
How much for rotors ... Are they stock .. How much life is left on them ???
iceman1
Post by iceman1 »
any chance the ECU is still there?
Me again from the USA..we are trying to crack the 2006 Eclipse 3.8L mivec ECU here..looking for the plugs and pins to make a plug and play set up.
One of our members has sucessfully wired his own stand alone AEM and tapped the stock ECU!!
Complete new wiring harness..so far he has leaned it out by 15% and got mad power..
any pics of the ECU pins would be great...we have contacted the Mit supplier of the ECU but they wont sell us the male plugs...
overboostin007
ecu harness
I'll get some pics up mate
overboostin007
rotors
Rotors seem fine, other then the surface rust. Heaps of meat left on them. $100 for the 2 plus post
kni8ht
Re: half cut
Post by kni8ht »
overboostin007 wrote:cb stepper motor and alternator is available. pm for price
could I have the stepper motor if cb don't want it .. what price we looking at? thanks
k3nz0_84
ecu
Post by k3nz0_84 »
hi guys,
if the ecu is still there, isit for sale? my engine fuel mixture is screwed, mechanic (lee) says its the ecu.
overboostin007
ecu
Yeah ecu is for sale. $80 plus post and it's yourz
Nevermind about the suspension parts, the mechanic tracked down the part today... turns out I snapped the stabiliser bar :oops:
