FOR SALE!!!!!!!!!!RPW extractors and engine pipes:[b] SOLD!!
Well, they only supply gaskets that connect the rpw supplied parts together. So from the end of the collector pipe to your cat you have to find your own... but I was in a workshop, they had half a dozen sizes onsite.
GR / GPX are equally as painful to fit, its when you try to put a GPX set on a GR or vice versa is when you run into difficulties.
jonowong
Post by jonowong »
well i meant easy as nothing can go terribly wrong :P
overboostin007
extractors
Post by overboostin007 »
Are these for the gpx?
vannil
Post by vannil »
yep im pretty sure but they fit on both
overboostin007
extractors
Any idea on what postage would be to postcode 4124 in qld
vannil
Post by vannil »
well i know to sydney its about 12 dollars so to qld im guessing about 25
khunjeng
Post by khunjeng »
vannil wrote:well i know to sydney its about 12 dollars so to qld im guessing about 25
with that weight? it will be more than that I suspect
vannil
Post by vannil »
nope there under 10kg for the pipe and extrators and if i dont get a better offer there being sold on monday
