kermut wrote:hey 18A4RE how much more do you want to boost it? i ran 9psi once for a lilttle bit was awsome but hot days 4get it all the way down, but 9psi was nothing compared to 2bar lasted 8 minutes then kaboom, i opended the bottom end up one piston survived, conrods were no were to be seen haha, bt was the best 8 mins ever : D...got a new engine now 75k on the dial straight from japan
WHAT? you ran at 2 bar? You crazy man lol.
What do you reckon the maximum poundage the stock engine will handle safely?
projector works fine $250 : )....retrofitted with HID globe.... i wouldnt go more then 9psi cause when i ran 9psi 1st time around and pushed it i had bent spark plug electrodes and the car wouldnt start....im guessing thats from a stretched rod or i needed a higher heat range plug ? not sure but i backed it off ...don't go more then 9 but seriosly i wouldnt go more then 8psi btw what torque did u get?
