Toyo R888 / Federal 595
- Gholdwayne
Re: Toyo R888
Oh sorry ben, that was for 595SS
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- aza013
- NSW Coordinator
Re: Toyo R888
Bennoz wrote:Damn you & your cheap prices for 17's![]()
- SG
Re: Toyo R888
Do they rub on the inside?aza013 wrote:235/45/17's $260 each for the 595 RSR's on the car ready to go.
- aza013
- NSW Coordinator
Re: Toyo R888
At full lock yes.
- SG
Re: Toyo R888
What about when you corner hard? Do they rub on the spring at all? Worried about the extra sidewall movement when i finally get a pair of r-comps.
- aza013
- NSW Coordinator
Re: Toyo R888
No rubbing on the track.
What rim size are you running?
- SG
Re: Toyo R888
Hrm
Im running 17x8 +35. But theres only about 5mm of room on there now between tyre and spring tyres are 235x40.
What offset are yours?
- aza013
- NSW Coordinator
Re: Toyo R888
As far as I can see they are +35
when you first put the tyres on you get some small rubbing untill you run them in about 6 laps on the track.
- Gholdwayne
Re: Toyo R888
are we talking about coilovers or shocks+springs ?
If this is with shocks+springs, then we are looking at the tyre hitting the base of the strut plate, or whatever that is called.
I think if you are running coilovers, maybe if you are game enough, you can use spacers to avoid the tyre hitting the coils ? im just theoryrizing
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- aza013
- NSW Coordinator
Re: Toyo R888
Yep I am running stock springs and shocks and they only just hit.
So as soon as I change over to coilovers I could even go to 245's
- Gholdwayne
Re: Toyo R888
i never knew you had stock springs+shocks aza!
i do remember my 215/45/17 was Just right for my old stock shocks+springs with the tiny bit lesser overall tyre diameter
What coilovers are you getting aza ? are you finishing your exhaust system first, or suspensions first ?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: Toyo R888
I had that issue with my old set up. With my old shock I just used an angle grinder to take a mil or 2 of the lower spring cup of the shock.SG wrote:Hrm
You shouldn't get anymore than 2-3mm tyre roll on the track, especially when hot.
Later on I used 5mm hubcentric spacers.
- SG
Re: Toyo R888
Ahh sweet. I keep having visions of the amount of roll v8 supercars get...
I thought coilovers had less room than the standard strut set up but it might just be uniformly the same as it is at the top on the standards
- bushido
Re: Toyo R888
Im going to try the T1R next. Cant find the 595rsr in a 40 profile.
Ideally I want a 205/40ZR17 and both the R888 and T1R come in that
- Gholdwayne
Re: Toyo R888
i might need a 40profile tyres, maybe just stick to the 45 for comfort and raise the ride height as my front inner metal guards are getting stripped of their paint and primer, and bare metal is getting exposed in a small section from the tyres rubbing onto it.
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- bushido
Re: Toyo R888
tell me about that rubbing problem. I have had it rubbing for 2 years now. but that bare metal is remarkably tough...
- Gholdwayne
Re: Toyo R888
im just scared it will rust and all...i can only fit 1 finger between the tyre and fender on all corners but thats how low i'm willing to go... for now? running on 215/45/17 on the front. anyone else get that inner metal rubbing? should i be extremely worried ? should i do something before its too late for, whatever ?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: Toyo R888
Ok just got priced, good deal??
225/35/18 Federal 595RS - $209
- bushido
Re: Toyo R888
I wouldnt worry too much about it.. I have had mine rubbing for ages and its just wears down slowly..
- aza013
- NSW Coordinator
Re: Toyo R888
Get the RSR's if you can mate they are a lot better.I8A4RE wrote:Ok just got priced, good deal??
But $209 for the RS is a good price for 18's, I payed $180 for the 235/45/17's
