Good place for manual conversion? Quoted $990
Re: Good place for manual conversion and engine rebuild/swap
:facepalm2:
Pretty sure they'll be able to handle that brain surgery mate.
Akys
Manual Conversion
Post by Akys »
Sweet. Thanks a lot Ben. Sorry I am a noob, still learning about all these.
I'll drive down tomorrow and have a chat with Pete. Hopefully things will turn out well. BTW, how much did you paid for the HD clutch kit? Is it necessary to replace the clutch kit?
nikhan
Post by nikhan »
Yeah might as well do it since the car is apart. U have to do it some point later so save the trouble and money and do it with the MC
This ^
Yeah the clutch kit was about $390 from memory.
Lawso
Penis Fingers
Post by Lawso »
And selector fork as we discussed
There's nothing wrong with the fking fork! And I blame Craig for convincing you that it was.
You cannot bend them.
Akys
Manual Conversion
Re: Good place for manual conversion? Quoted $990
Post by Akys »
Spoke to Pete from suzukitech today. he quoted me $990, takes about 2 days. I supply all the parts. He also mentioned he'll take a look at the clutch kit and tell me if i need to replace them. Very nice and friendly person. Thanks Ben.
What do you guys think about the price? Labour + parts = $1600/+-(excluding the HD clutch kit)
was hoping to get it done cheaper so I can save some money for the engine, so tell me what you guys think
Personally I think that's on the money.
Realistically it's a prick of a job, and out of there ordinary line of work, so yeah. seems on par.
In my opinion.
Thats a pretty good price I reckon. Considering most shops (Suzitech included) charge around 90 bucks an hour labour.
2 full days of 7.5hrs @ $90/hr = $1350. So you're getting a $360 odd dollar discount from normal rates.
He's a nice guy Pete, he'll look after you ;)
I too believe thats a pretty damn smick price.
Akys
Manual Conversion
Post by Akys »
Sweet. Thanks guys. Hopefully I'll get it done soon. after I get all the parts.
P:S Ben, Pete ask if you can list out all the parts needed so that we dont miss out on anything
Cassar2610
Post by Cassar2610 »
It seems to me that unless your car is very special to you, it is almost better to sell it and buy an existing manual car...
Though I have fantasized about a manual conversion for a few years now, well ever since I was charged 2K to fix my auto box when it died on me 2 weeks after buying the car. Though that was a few years back now :(
Akys wrote:P:S Ben, Pete ask if you can list out all the parts needed so that we dont miss out on anything
Im having lunch down there today, I'll let him know ;)
Now's the time to ensure you have absolutely everything that's needed so it doesn't take longer than necessary.
Make a list, check it twice, Santa Clause, etc.
Gholdwayne
Post by Gholdwayne »
Lol :lol:
what an 'illustrating santa' kient :lol:
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Akys
Manual Conversion
Post by Akys »
Cheers Ben. dont mind if you pass me the list as well. I got some info from the irish club FTO as follow:
"MANUAL GEARBOX
Abvious one but make sure you also get the following with it. Gear cable mounting bracket. Clutch Fork including the release bearing retainer clip.
Clutch pipe mounting bracket.
The engine mount brackets are the same on the tip and manual boxes so you will already have these.
You also need the engine mounting on top of the box as the tip one is different.
GEAR SELECTOR UNIT AND CABLES
Again an obvious one but make sure you get the gear knob and leather gaitor.
COMPLETE CLUTCH KIT
Do not use a previously fitted clutch and release bearing.
REVERSE LIGHT SWITCH and CONNECTOR
The switch is fitted to the top of the manual box, and you will need the relevant connector cut from a manual wiring harness. Yes you can work around this but it can be messy and possible water ingress afterwards.
CLUTCH/BRAKE PEDAL ASSEMBLY UNIT
38mm HOLE SAW
This is need to bore the hole in the firewall to fitr the clutch servo unit.
CLUTCH SERVO, SLAVE CYLINDER and PIPING
Again make sure the piping and fluid cover is supplied. "
Lawso
Penis Fingers
Post by Lawso »
Now I just need to get the f**king thing out...
Akys
Manual Conversion
Post by Akys »
Cassar2610 wrote:It seems to me that unless your car is very special to you, it is almost better to sell it and buy an existing manual car...
I know, I've thought about it but it won't be the same as I've had put in effort to make this car run better. Getting another FTO also is another risk. Better to deal with the devil i know then the devil I dont.
lawsochap wrote:Now I just need to get the f**king thing out...
Yup. haha. How is everything going?
Bennoz wrote:There's nothing wrong with the fking fork! And I blame Craig for convincing you that it was.
Blahaha... But they do wear out... Depends on how the box was treated... But had to do this to my Evo project...
As for the mechanic, I was going to recommend RICOL.. They have worked on more FTO's then you can count.. But are not in the west... Are located at Peakhurst
