Big brake kit
- fraz91
- Hair-do
Re: Big brake kit
What do the engineers deem as a "20% increase in braking capacity"? Does it have to be an increase in rotor/caliper sizes front and rear? or just in the actual braking performance of the car? Surely braided brake lines, good slotted rotors and pads all round should give you a 20% increase in performance?
Also, would it be worth looking into the brakes off a 380? I'm not sure if it was the triton or magna crowd, but I remember someone looking into adapting the 380's calipers and rotors to suit their cars.
Re: Big brake kit
Guys I know this may well turn out to be something completely custom, I'm a qualified mechanical engineer remember.
And the next person who says to me "A good set of slotted rotors & pads should be all you need" is going to get slapped. Because it's clearly fking not the case! I've worn out a 330mm big brake kit rotor & have been on the phone to a dozen smug brake 'experts' who have all been telling me "A good set of slotted rotors & pads should be all you need"
I have asked the RTA engineer to specify exactly what the 20% increase relates too. He's 'faxing' me (yeah I know... faxing) some documentation tomorrow. It's to do with surface area, but there is also a fluid volumes requirement on top of that from what he was saying.
Just to refresh memories, this is what I've been using (and have now worn out.) Gotta remember & I'm carrying more weight than most FTOs & have more than twice the power. I hit much higher speeds on the track, coupled with some fairly aggressive pads, I've gouged out, cracked & fractured the discs pretty badly.
- Shane001
Re: Big brake kit
They do look like a pretty sh*t rotor though, not very thick for a 330mm?
How long have you had this set on for? Any after pics
Re: Big brake kit
Been on for about 5 years. Yeah they're only 24mm thick.
Ok, so today I'm going to visit wreckers! I'v been speaking to some Mitsi parts gurus this morning.
Apparently the Evo 5 hubs fit into the FTO with no mods... and onto a Evo 5 hub, I can direct bolt on the 4 pot Brembos & 320mm x 32mm rotors that come standard on the Evo 6.
The guys in the pommy colt club have been doing this conversion for years.
Interestingly enough, the Evo 5 lower control arms are also interchangeable with FTO. They're alloy & supposedly stronger & lighter than the steel ones we use. Also have mount points on them for a GPvR style swaybar.
So, i'm off to SSS this arvo with some FTO bits & will do some comparisons. If all of the above is true, then techncially its a 'factory' upgrade!
- bass_twitch
Re: Big brake kit
WINBennoz wrote:Been on for about 5 years. Yeah they're only 24mm thick.
- Shane001
Re: Big brake kit
Massive WIN
Will be watching this thread with interest!
And the EVO V hubs are 5 stud, and 69mm centre bore, more WIN
24mm, really a bit thin for a 330mm rotor, should be minimum 28mm for that diameter, but they did last 5 years, so...
- Gholdwayne
Re: Big brake kit
Yeah it'd be intresting for us all to be able to do this 'factory' upgrade!
Wait, did you need a 69mm centre bore? coz fto's have 67.1mm...
Shane001 wrote:
And the EVO V hubs are 5 stud, and 69mm centre bore, more WIN![]()
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- Shane001
Re: Big brake kit
No, FTO is 69mm.Gholdwayne wrote: Wait, did you need a 69mm centre bore? coz fto's have 67.1mm...
- Gholdwayne
Re: Big brake kit
Im confused... Are you referring to the one that sticks out of the rotor and secures the wheel?Shane001 wrote:No, FTO is 69mm.Gholdwayne wrote: Wait, did you need a 69mm centre bore? coz fto's have 67.1mm...
I distinctly remember being pissed for buying a Nissan spacer with a 66mm centre bore, and not being able to fit, resulting with me having to buy another set that suits Mitsu which had a 67mm centre bore... (correction, i think it was 67mm without the .1
Well mine has 67mm... at least the part that im talking about
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Shane001
Re: Big brake kit
- Gholdwayne
Re: Big brake kit
Shane001 wrote:you're right, it is 67. I was looking at the DBA catalog, lists it as 69, should have known...
Phew, thank God
/Endthread
LOL Just kidding, its not my thread!! trollolol!
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Shane001
Re: Big brake kit
You know the annoying thing about this, I've been looking for replacement rotors going off the specs from the DBA catalogBennoz wrote:Shane001 wrote:you're right, it is 67. I was looking at the DBA catalog, lists it as 69, should have known...
Yeah I know, stupid me right
I'll check my 'cracked' DBA rotors later and see if they are actually 69 or 67
Re: Big brake kit
Will go into spec detail later tonight...
Big brake kit
Oh f**k yeah best find
How much and what's the condition?
- aza013
- NSW Coordinator
Re: Big brake kit
Bennoz wrote:![]()
I'm liking what I am seeing
Re: Big brake kit
Daaaaaauuummm...
- Kustom
Re: Big brake kit
suitable meme placement.
- phunkydude
Re: Big brake kit
Research, solution, acquisition, implementation.
All in 2 days time. Love your productivity!
- FTO_GPvR
Re: Big brake kit
Awesome
