gear box n computer
Taiwo
Re: gear box n computer
Post by Taiwo »
Yea I just took it out n definitely 3 pin output n 4 pin input. I will post up pick shortly
"Is that a supra???".
"What's a Mitsubishi FTO?"
Taiwo
Post by Taiwo »
This is what it looks like.
That's not the output sensor that's for the speedo. The output and input look basically the same. It will be a 4 pin as well trust me.
Taiwo wrote:Image
The geared sender unit on the left of the pic is the speedo drive gear, its drives the speedo needle. The sensor on the right is either the gearbox input shaft speed sensor, or the output shaft speed sensor. As Taz say, there will be another one on the box that is the same the one pictured on the right. There are 2 of them.
Taiwo
Post by Taiwo »
oh trueeeee. i will have a look for it no wonder i got so confused cause i went on google to see what it would look like and i got those two pictures
Taiwo
Post by Taiwo »
i just got my sensors chucked them in but there is something blowing the fuse when i put it in gear not sure what it is.
thinking i might take it to an auto electrician
Taiwo wrote:Image
That's the output speed sensor. The input speed sensors plug points upwards.
Necromancer :cheers:
Also a flashing N light can mean more than just an input/output sensor!
