1000wat option audio subs from the states
- Connor_1994
Re: 1000wat option audio subs from the states
Sweet,
Yeah just let me know guys
- ZFL45H1
Ok well I'm keen for one send me a pm with how u want payment cheers prob be this week Wednesday
- Connor_1994
^^Random^^Connor_1994 wrote:Pic of engine in a sub thread![]()
![Confused :?](./images/smilies/icon_confused.gif)
- phi-tec
the sub is in the engine?
- Connor_1994
Lol, its a photo for Reign
He wants the fuel input for the end of the rails lol
So i uploaded a picture for him to see haha
ITS POSSIBLE. F**K YOU GUYS! HAH!
http://www.ebay.co.uk/itm/1995-MITSUBIS ... 564wt_1397
Woohoohoooo! The idiot was right for once!
Daniel2019 wrote:Woohoohoooo! The idiot was wrong again!![]()
Thats in the seat back, you said the seat base as wellDaniel2019 wrote:If youre feeling really creative you could put one in the middle of the back seat on the horizontal cushion and one on the vertical back
![Spaz :geny:](./images/smilies/icon_spaz.gif)
The point is that its possible. The seat back would only be slightly thicker than the base in the centre because its slightly raised, and as I said, with a bit of creativity it could be done.PHIL069 wrote:Daniel2019 wrote:Woohoohoooo! The idiot was wrong again!![]()
You do know that there's a big hole behind the rear seat that leads into the boot right? So most of the sub would stick out into the boot.Daniel2019 wrote:The point is that its possible. The seat back would only be slightly thicker than the base in the centre because its slightly raised, and as I said, with a bit of creativity it could be done.
Thats where the partition comes into play. If a sub box was made to fit between the two seats and sit up higher above the cushion, it could house the sub. So there would be 1/3 to 1/2 of the sub/box mounted into the cushion and the other 2/3 to 1/2 sticking out.Vectose wrote:You do know that there's a big hole behind the rear seat that leads into the boot right? So most of the sub would stick out into the boot.Daniel2019 wrote:The point is that its possible. The seat back would only be slightly thicker than the base in the centre because its slightly raised, and as I said, with a bit of creativity it could be done.
Great idea, do itDaniel2019 wrote:Thats where the partition comes into play. If a sub box was made to fit between the two seats and sit up higher above the cushion, it could house the sub. So there would be 1/3 to 1/2 of the sub/box mounted into the cushion and the other 2/3 to 1/2 sticking out.Vectose wrote:You do know that there's a big hole behind the rear seat that leads into the boot right? So most of the sub would stick out into the boot.Daniel2019 wrote:The point is that its possible. The seat back would only be slightly thicker than the base in the centre because its slightly raised, and as I said, with a bit of creativity it could be done.
Would look good in your car.........
I see what you did there........ ![laughing :lol:](./images/smilies/icon_lol.gif)
If I get bored when school finishes then I'll have a go.PHIL069 wrote:Great idea, do itDaniel2019 wrote:Thats where the partition comes into play. If a sub box was made to fit between the two seats and sit up higher above the cushion, it could house the sub. So there would be 1/3 to 1/2 of the sub/box mounted into the cushion and the other 2/3 to 1/2 sticking out.Vectose wrote:You do know that there's a big hole behind the rear seat that leads into the boot right? So most of the sub would stick out into the boot.Daniel2019 wrote:The point is that its possible. The seat back would only be slightly thicker than the base in the centre because its slightly raised, and as I said, with a bit of creativity it could be done.![]()
