UAS airbox Schematics
- shadowarrior
- Tightarse
Re: UAS airbox Schematics
any rough estimate on costs?
I'm thinking $50 a box
That's what is sell them for.
- shadowarrior
- Tightarse
Put me in for one
will it fit the stock intake pipe feeding off a 3.5inch pod though?... have to live with the stock pipe till i can source an arc or uas pipe. But i definitely need a box.
It'll be a 3" hole.
But I could ask for it to be bigger.
silverGPX wrote:It'll be a 3" hole.
Hahaha just cracked up so loud at work
- shadowarrior
- Tightarse
LMAO@BENZ!!!
The UAS and Arc pipe's end is a 3 inch as well I think? Can someone with an UAS/Arc confirm this? Or does the UAS use an adapter and choke down to 2.5 to connect it's UAS shroom pod?
I think 3" would be an appropriate size for multifitment.
Most sillicon pipes and joiners etc are 3" and the throttle body is 3"
- shadowarrior
- Tightarse
Cool, then I'll keep the box's hole at 3". Are you getting one made for your car first?
That's the plan.
Where it says to rivet it, I won't rivet it in going to use small bolts with washers.
The internal diametre of the UAS tube is 4 inch. The external diametre is even bigger. It's a thick bastard.
If these actually get made them I'm definitely in for one
Haha it'll get made.
The lady doesn't come back for three weeks though, so can start making bulk.
I'll probably do a group buy for 10.
- shadowarrior
- Tightarse
Which reminds me. I called them up again....they are happy with a 6 people group buy down from 10 in order to start manufacturing a fresh batch. Price is till high up in the sky at $350 though for the entire kit.Bennoz wrote:The internal diametre of the UAS tube is 4 inch. The external diametre is even bigger. It's a thick bastard.
Back on topic of Matt's intake box.
How much for just the pipe ask them?
I can easily make the hole size bigger.
- Shhtuart
ARC is a 3.75" opening at the airbox side. I know coz it took ages to find a silicone joiner to fit.
- bass_twitch
Yep was going to say that..Bennoz wrote:The internal diametre of the UAS tube is 4 inch. The external diametre is even bigger. It's a thick bastard.
3" wouldn't fit UAS pipe
Most people dont have a UAS pipe so im going to go with 3".
