Is it common for GPX to blow head gasket / loose compression
Re: Is it common for GPX to blow head gasket / loose compres
silverGPX wrote:Lol yeah your a pussy
*you're
NextLevel
Post by NextLevel »
*you're
lol.
have not filmed yet cause it's hard to keep the engine idling while filming the sound at the same time.
i will try again, tonight.
NextLevel
Post by NextLevel »
here it is fellas:
Engine at idle. Foot on gas to keep the car from stalling. (note there is a loud knock that happens in the clip also)
This is the sound of the exhaust. Foot on gas to keep the car from stalling. (note there is a loud click/knock sound as well)
Sounds like an old Ford we used to have when I was at my last job 8O
Photofucket. :roll:
Well, I'm not listening to it then. :lol:
Astron_Boy wrote:Photofucket. :roll:
Still trying to get the hang of this new weird thing called "the internet" are you pops? :lol:
No, just my dislike of bloatware.
Seriously, who makes a site consisting of so much sh*t.
Apart from Zuckerberg.
(I digress, off topic.)
That sounds like its running on 3 cylinders, check your coilpacks, leads.
Also is your map sensor plugged in?
All of the above ^^^
Check all electrical plugs.
Have you done any work on it recently?
NextLevel wrote:7,500-8000rpm on 1st and 2nd gears. Pointless to hit MIVEC on the remaining gears.
I agree, I have never hit 8000-8750rpm in any of my gears.
Mivec in 4th is a beautiful thing :twisted:
Redline is 8250......
I didn't used to like taking mine past 8k. Generally hit the shift up on tip at about 7,700/7,800 and it would shift pretty much on 8k.
half the fun is playing the game - how close can u shift before it red-lines? :lol:
Not in mine, I have no rev limiter, at 8900 my engine "drops off the edge" so to say.
I have pushed it to find the "edge", thats why I shift when my LEDs all flash at 8000.
Ummm... I know you're the infinitely better mechanic and all Phil, but wouldn't there be a limiter at 8,250 for a reason?
Hence why he doesn't shift past 8k. :lol:
I was thinking more along the lines of why would it be de-limited in the first place :lol:
Daniel2019 wrote:Ummm... I know you're the infinitely better mechanic and all Phil, but wouldn't there be a limiter at 8,250 for a reason?
Couriosity got the better of me, I just had to know where the "edge" was as I don't have a limiter.
I do have a cold engine limiter at 4000, but no full engine limiter.
I change when my lights tell me too which is at about 8250-8500 by the time I react to the 8000rpm flashes.
Normal cold limiter is at 6k.
