Tyre width grip difference
Re: Tyre width grip difference
They'll probably do a better job too.
Although I seem to have gotten quite good at digging lately...
c3rbera
Post by c3rbera »
215,235, could go somewhere in between? Though I'm no expert I've got 225s and they seem alright. Still a good improvement over stock, no guard rolling needed either (saw your other thread bjk).
Hey I say the more tread the better, how often do you replace tyres anyway? :twisted:
silverGPX wrote:Nice supra
Manual '95 GPX
I threw my car around a few corners today and it stuck so well and thats with stretched 225s :)
silverGPX wrote:Sahin threw my car around a few corners today and it got stuck to a wall
EFA
:(D):
There's a set of 18x9 +18 rims near adelaide for $900. Might try to see if I can haggle a bit. Also need to see how cheap I can get the tyres I want here in SA.
c3rbera
Post by c3rbera »
Any photos? 8)
Manual '95 GPX
When I get home mayb!
c3rbera
Post by c3rbera »
bjk wrote:mayb!
:roll: Hoohhh-kayy
Manual '95 GPX
c3rbera
Post by c3rbera »
Yolo
Manual '95 GPX
F**k. This, children, is why you don't forum while walking from one thing at work to another. You miss letters and look like you can't spell for sh*t. :lol:
The 235 tires would have a higher profile than the 215.
Use some tire size calculators to figure out which is best suited to the original 205/50/16 tires
spetz wrote:The 235 tires would have a higher profile than the 215.
This is the closest you'll ever get.
You always want to be a bit over than under.
Code: Select all
Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
205/50-16         4.0in  12.0in    24.1in         75.6in        838        0.0%
225/40-17         3.5in  12.0in    24.1in         75.7in        837        0.1%
225/35-18         3.1in  12.1in    24.2in         76.0in        833        0.5%
Meanwhile, 225/40-17 isn't much the norm.
EDIT:
To give an idea in comparison to the majority of FTO owners with 17s.
Code: Select all
215/45-17         3.8in  12.3in    24.6in         77.3in        819        2.3%
235/45-17         4.2in  12.7in    25.3in         79.6in        796        5.2%
Which is why I'll probably run 235/40. I've found pictures, barely any stretch at all on a 9 inch wide rim, but probably depends on the tyre too.
