Rear abs hubs $15 each
- vanadinite
Re: Rear abs hubs $15 each
Any ideas on what that thing is above the throttle body? it is like a circle thing and links to the throttle butterfly, it has a sensor beneath it too that is also connected to the throttle body?
Pic?
My guess is TPS but am probably wrong.
Same as what I am getting, why don't u add Into my abs help thread? I'm 99% sure we need an evoscan cable to clear the codes.vanadinite wrote:ideas? since i've owned the car the TCL off light flashes until i hit the TCL off button. The only errors i get are about the sensors, such as rear abs sensor open and rear abs senor ???......
I've cleaned and changed my sensors though, have u?
- vanadinite
Yeah i have cleaned them twice to be sure.
I never added to it before because i never put to much thought into it, I had bigger issues on my mind. Brakes obviously work fine and never had abs before so never worried about it. Am endeavouring to fix it now though.
- vanadinite
Ill move this convo to the abs thread now
u can the hubs for $30 if u want them matt
Bendix what????destinationtoby wrote:Also have a set of brand new rear brake pads, still in the wrapper, I think they are bendix something, honestly can't remember , bought them a year ago and just found them.. $25 + $10 postage
If Bendix Ultimate, I will take them.
I'm not sure man, lost the box they are just wrapped in the plastic :/ unless it ultimate is written on the actual pad itself or something? Ill look in the morningPHIL069 wrote:Bendix what????destinationtoby wrote:Also have a set of brand new rear brake pads, still in the wrapper, I think they are bendix something, honestly can't remember , bought them a year ago and just found them.. $25 + $10 postage
Which pic matches your pads...
- Bendix CT 01.jpg (38.11 KiB) Viewed 506 times
- Bendix CT 02.jpg (55.79 KiB) Viewed 506 times
- Bendix ULT.jpg (56.57 KiB) Viewed 506 times
Last edited by destinationtoby on Sat Jul 27, 2013 6:29 pm, edited 1 time in total.
There you go it says ultimate on them
PM me how you would like me to transfer the money.
Pads sold!
Last edited by destinationtoby on Sun Sep 22, 2013 10:34 am, edited 1 time in total.
Item received, Thanks
Rate this transaction
Positive Neutral Negative I'll leave Feedback later
Tell us more
" Great item, Fast Delivery, Will shop here again, Thanks "
1 character left
Rate details about this purchase
How accurate was the item description? Very accurate
How satisfied were you with the seller's communication? Very satisfied
How quickly did the seller post the item? Very quickly
How reasonable were the postage and handling charges? Very Reasonable
Tell us more
1 character left
Cheers mate
5 stars for u aswell buddy
Bump.
Rear abs hubs. $25 for the pair+ postage.
Last edited by destinationtoby on Wed Aug 21, 2013 8:00 pm, edited 1 time in total.
New bearings?
Bearings can't be replaced on these.
Are u sure? Owner told me they were all new. Theres a receipt that says wheel bearings replaced front + back.Vectose wrote:New bearings?
But if your sure? Ill correct it...
Yeah, I am sure.
If you could there would be a DIY up for it. But the bearing is part of the hub. Can't be replaced.
Only way they're new is if the whole hub was replaced.
Righto, cheers!Vectose wrote:Yeah, I am sure.
