Error codes
Re: Error codes
Excellent ill try alloftheabove. Cheers
Re: Error codes
So the engine light doesn't flash at me any more..
But the speedo gauge has stopped working? .....
Re: Error codes
destinationtoby wrote:So the engine light doesn't flash at me any more..
That's because you broke the engine light and the speedo :twisted:
BorepYano
Re: Error codes
Post by BorepYano »
in true engineer term: flashing engine light issue, fixed.
Re: Error codes
Nahh becos both the speedos on both clusters aren't moving, and they both worked before... So it's the sensor?
Re: Error codes
Sensor or wiring or plug possably
Re: Error codes
When I use the aircon, the error code appears constantly for the the speed sensor still :lol:
When I turn air con off, error code goes home :D
Still no speedo working. *~delightful!~*
Re: Error codes
Test the sensor, the instructions are in the manual. The test requires you to turn the gear While hooked up to a multimeter.
I'm betting on a harness issue which you can also test and instructions are also in the manual.
Re: Error codes
I bet it's coz he fucked up the manual conversion
Re: Error codes
Sounds like u tapped into wrong wire for reverse
Re: Error codes
Broke it.
Re: Error codes
Sahin wrote:I bet it's coz he fucked up the manual conversion
Well yeah it did go at that time :lol:
silverGPX wrote:Sounds like u tapped into wrong wire for reverse
Explain more please? I could of easily done this. But wouldn't that mean I'd have no reverse signal and beep beep
Re: Error codes
I'm not sure tbh. That's the only wiring I was aware of that was needed with a manual conversion. Could you of possibly needed a manual ECU?
Re: Error codes
I've got the manual ecu in
Re: Error codes
Re: Error codes
It has to be something simple. I don't get why I would have to test the sensor. It works,It's brand new and I've tried two others.
Ben, will the car start and run if I swap out the manual Ecu for the auto one to see if it works?
Re: Error codes
There are no manual or auto ECU's. They are all the same except for mivec vs non mivec and slight changes over the years.
Auto FTO's have an additional ECU for the transmission.
Re: Error codes
Actually. There is a different main ECU for traction control models. I know this as I put a "standard" ECU in mine and traction control did not function. Put "TCL" ECU back in, traction control functioned
Re: Error codes
And I was told to swap the ECU's when doing the conversion by a few, from memory.
Yesterday It kept blowing fuse 3 when I put it into rever.... Input and output shaft speed sensor... So that's the one on the back of the gearbox yeah? Why would reverse be causing it to blow :|
Re: Error codes
Did you use your auto loom? Did you hook up the two wires that turn your reverse lights on properly?
