How to buy a FTO straight from Japan?
Eltnot
Re: How to buy a FTO straight from Japan?
Post by Eltnot »
dstocks wrote:Because the GPvR stuff that is worth having can be almost impossible to source (LSD, different suspension setup etc). Finding a Version R being dismantled is even rarer than finding one to buy.
http://www.camskill.co.uk/m3b0s12p80310 ... to_01_1997
http://www.camskill.co.uk/m3b0s586p0/Mi ... lover_Kits
Still cheaper to get the GPX. Yes, there's sway bars and other stuff, but there's also the price difference of a few grand too. 3-4k in after markets parts is still going to be cheaper than importing, and the parts are new, not used.
But the splines! THE SPLINES!!
woot woot
Post by woot woot »
What is it with the splines?
I was wanting to go down the route of the GPX but also hard to find a good one. And plus the GPVR is pretty much ready to go.
If i was going to get a GPX i would get a Quaife ATB lsd,
http://quaife.co.uk/shop/search/results ... C284%2C285
but since the GB has to come off i would get a light weight flywheel to make it rev much faster
http://www.xtremeclutch.com.au/en/produ ... -flywheels
Also with coil overs i have been in a few cars with many different brand of coil overs and by far the most comfortable ones that are very well made are these.
http://www.fortune-auto.com/products.htm
They are so comfy it is worlds of difference between say a BC coil over which bangs over certain bump while these will absorbed more of it
I would also fit some sways but really depends on the roll centre of the car, as with stiffer sways you can run softer shocks and let them do more work, or just run standard sways and have super hard springs
Why don't you just get the car and then think about modding lol
vanadinite
Post by vanadinite »
woot woot wrote:What is it with the splines?
Read this, viewtopic.php?f=24&t=28036&p=358732&hil ... any#p358732
The writeup is half way down.
woot woot
Post by woot woot »
I would mod one if i could find one, lol but both GPX is rare in good condition and GPVR is even harder. Or they are modified to the point it is not worth it as they impossible to register here in vic due to very harsh rwc regs
Coolio for the info on LSD. That looked like a headache for you. I presume if i just got a lsd transplanted into the normal non lsd gb it would not require all the splines and other things?
vanadinite
woot woot wrote:I would mod one if i could find one, lol but both GPX is rare in good condition and GPVR is even harder. Or they are modified to the point it is not worth it as they impossible to register here in vic due to very harsh rwc regs
It depends what LSD you get as to whether or not your gonna need different drive shafts. For instance if you get that cams kill one your gonna have to track down a set of viscous drive shafts which are extremely hard to find. If you get a wavetrack or quaife your gonna need 27 spline shafts. It all depends what LSD you get as to what drive shafts and stuff you'll need
Yep, when I said LSD is difficult to locate, you need the matching driveshafts as well. There are a few people now that have found out just how hard that one is to sort out. Much easier just to buy a version R if you are going to end up wanting the extra suspension goodies anyway.
    c3rbera
    Post by c3rbera »
    Unless you go with a helical LSD..is that right? The trouble really doesn't sound worth it either way..
    silverGPX wrote:Nice supra
    Manual '95 GPX
    vanadinite
    c3rbera wrote:Unless you go with a helical LSD..is that right? The trouble really doesn't sound worth it either way..
    Helical uses 27 spline drive shafts so you'll need these if you don't already have them. Most fto have 25 spline shafts but it's a mixed bag of cats really so you may get lucky and have 27 spline shafts. Easy way to tell what you have is measure the diameter of your drive shafts. The easy part about the helical is all 27 spline shafts work unlike the viscous where you need to find the correct stubby shafts which are unique to the viscous lsd. Hope this helps
    c3rbera
    Post by c3rbera »
    Jesus christ...well they made that nice and simple hey. :| Lol I don't think it's something I'll be doing, think rebuilding the gearbox is enough to do.
    Manual '95 GPX
    vanadinite
    Yeah it's a massive headache and took me a week to work it all out. Once it's explained it's simple but getting that explanation isn't an easy task
