BC BR setup
Re: BC BR setup
Lmao!! :P
And extractors and Rallisport exhausts.. :)
Re: BC BR setup
As per what Rob posted. Oh & you'd already know that if you read the instructions that come with your BCs ;)
Re: BC BR setup
Bennoz wrote:...instructions...
:roll: :roll:
Re: BC BR setup
Sahin wrote:I'm back on the 5th lol f**k melbourne
What happened? 8O
Did your dad rev your FTOs cold engine at 3am? :lol:
Re: BC BR setup
No way! I read it twice and read it again just now after checking your post... nothing there says its already set at proper preload. Unless you mean this line: 'BC's shock absorbers are designed and produced according to the dimensions of initial factory'. :)
I even got new reading glasses now!! :P
All good with the rears, they are in, no dramas, will put the front ones in tomorrow, and then the camber and toe arms.
Re: BC BR setup
shadowarrior wrote:No way! I read it twice and read it again just now after checking your post... nothing there says its already set at proper preload. Unless you mean this line: 'BC's shock absorbers are designed and produced according to the dimensions of initial factory'. :)
I'll scan & highlight the section when I get home. They do not use the word 'preload'
Re: BC BR setup
Wait..let me re-read it again! :P
Re: BC BR setup
Under 'How to adjust ride height'. "If unnecessary or unchange spring length, please don't lossen and move pallet F" ?
F being the locking nuts below the spring. That part? :)
Re: BC BR setup
how to disconnect the brake line from the front shock tower...the thing won't budge...thought it was a clip which slides in between and holds it in place?
Re: BC BR setup
The c clamp slides off and the brake line comes out after that
Re: BC BR setup
Use a flat tip and some muscles if you have some
Re: BC BR setup
Done...was a bitch...rusted and stuck... shouted out loud Hail Sahin and the clip slid right out!! :(D):
Re: BC BR setup
I could actually imagine you doing that hahahaha
Re: BC BR setup
Sahin wrote:I could actually imagine you doing that hahahaha
LoL :P
Re: BC BR setup
Are you done yet?
    Re: BC BR setup
    Well so far:
    Camber and Toe arms done
    Rear coilovers done
    Front right coilovers done
    Sanded bits of underbody rust and sprayed tons of fish oil anti rust (this took some time)
    Left to do:
    Front left coilover
    Rear control arm
    Rear whiteline swaybar (should arrive by 1st week of jan or so)
    Front and rear droplinks (should arrive same time as the whiteline bar)
    Rear trailing arm bush (most likely i'll give it to a mechanic for this)
    Front control arm bushes and ball joints (same, going to a mechanic)
    Outer CV... not sure if I can do this on my own, will check workshop manual
    Tie rod ends
    Front sway bar bush.
    Upper engine mounts.
    whew :)
    Am working throughout the holidays so can only work on the car for couple of hours after work each day. :\
    Re: BC BR setup
    I know it's in 'Chingrish' but I thought it was clear enough..
    Re: BC BR setup
    Lol yeah found it that night. :) I thought that was normal instruction given to not use the preload for changing ride height, so brain skipped that part for the first couple of reads :P
