I broke something....I think the Inner CV
Re: I broke something....I think the Inner CV
Not sure. But the axle just pops straight out of the cup after removing the boot.
shadowarrior wrote:? The other end of the inner cv is inside the gearbox i think?
The other end of the cup is the shaft that goes into the box,
shadowarrior wrote:
destinationtoby wrote::lol: don't pay $60 for it lol they were only $13 at repco
Actually they say they're universal 8O the ones you need are a particular shape to fit over the cups.
So HJ Galant inner cv boot from Repco/Burson/Supercheap?
Yep :)
I have a boot kit you can have for 20
It's the fto one
And you need circlip pliers to replace it... You need to remove the joint off the shaft
Don't just cut it so it fits over the joint like Toby did lol
Sahin wrote: And you need circlip pliers to replace it...
Compass :lol:
Sahin wrote:Don't just cut it so it fits over the joint like Toby did lol
The second pic...your steering rack boot.
If all that oil is coming out from inside the boot, then you have a leakn' steering rack.
Thanks Phil, going to search on re-conditioning a steering rack. :)
How to take the ABS ring out...and how to press it in for the new CV?
You don't need to! You're just changing the boot...
Sahin wrote:You don't need to! You're just changing the boot...
I am also changing the outer CV...complete kit...but it doesn't have the ABS ring..so need to use my old one.
I think u supposed to just get the cv with the ring?
I think :?
:facepalm2:
I think :?
Nope, called up the shop in ebay which Bennoz linked sometime back, asked them about the ABS variant, they said they don't have any ABS variant CV kits for the FTO, that I have to re-use the existing ABS ring. :|
http://www.ebay.com.au/itm/380508414135
I think the abs ring is on the hub isn't it?
Oh yeah mybad :cyclopsani: :lol:
I'm sure bennoz answered this question for someone not long ago
hmm let me search around.
flat head brass drift punch and a mallet will be used to get those rings out :)
Anyone know what size is that big nut on the hub? Will go and pick up a socket for it then. Think its a 22?
If its not a 22 its a 23.
    No one stocks a HJ Galant inner CV boot kit, they are trying to sell me universal ones :|
    Tried Repco?
    Also eBay.
