Lost power
Re: Lost power
Yes
Re: Lost power
Took it to the mechanic, it is probably a dead cat convertor that is causing the problem, won't know if it is the root cause of the power loss until I get it changed, though. Also need new front struts, strut tops and front sway bar D bushes.
Bushes are SPF1344-16k (do I need 2 or 4?)
Tops are 2 x SM6756
Struts are KYB 334155 and 334154
Re: Lost power
Supplanter wrote:Took it to the mechanic, it is probably a dead cat convertor that is causing the problem, won't know if it is the root cause of the power loss until I get it changed, though. Also need new front struts, strut tops and front sway bar D bushes.
Tops are 2 x SM6756
spf1344-16k come as a set of two which is all you need
Re: Lost power
Lol sahin the bush expert
Re: Lost power
She's back. :thumleft:
-Nighthawk-
Re: Lost power
Post by -Nighthawk- »
What was the issue?
Re: Lost power
-Nighthawk- wrote:What was the issue?
Dead cat.
Dead cat.
Dead cat.
Re: Lost power
Eh, just remove the cat :p
Re: Lost power
Dead cat three times!
Re: Lost power
Dead cat.
Dead cat.
Dead cat.
But was there enough room to swing one?
Re: Lost power
bjk wrote:
Dead cat.
Dead cat.
Dead cat.
It's an FTO, how could there be?
