Fto not firing!
Nuttsausage
Re: Fto not firing!
Post by Nuttsausage »
That's sounds about right man I'm gonna go back through everything today
Nuttsausage
Re: Fto not firing!
Ultra tune will run through their diagnostics procedure about an hour and a half apparently for $120
Re: Fto not firing!
BorepYano wrote: - Kmart left a 3/4 extension bar loose in my engine bay once; and way over charged for tyres another time
Free extension bar whats your problem? :lol:
I love finding tools in customer's engine bays :lol:
Re: Fto not firing!
Did you have to unplug or pull on the harness of the MAF sensor when you changed the air filter?
If you have bent a pin in the MAF plug or lossened a wire on the harness then your car won't start, it will get no spark.
Check the MAF wiring/connections/plugs/pins.
As Bennoz said, it will be something you touched.
Re: Fto not firing!
PHIL069 wrote:As Bennoz said, it will be something you touched.
Yea, Bennoz knows all about touching things :hey:
Re: Fto not firing!
Bens Big Balls.jpg (100.62 KiB) Viewed 991 times
BorepYano
Re: Fto not firing!
Post by BorepYano »
any luck?
give us a buzz later on in the day, (if you manage to wake me up) I might be able to pop around to have another look at it.
Nuttsausage
Re: Fto not firing!
I've left it for a few days, I can't figure it out hey I'm going to get a sparky to have a look at everything hopefully he can find it lol. Thanks everyone
Re: Fto not firing!
Bennoz wrote:They would definitely give a code. 2 actually if it was both, 22 & 23.
Hate to use the age old adage, if it was working before you touched it, then it'll be something you touched.
Actually when I had all my rebuild dramas it didn't throw a code till I revved the sh*t out of my tractor
BorepYano
Re: Fto not firing!
Post by BorepYano »
SchumieFan wrote: Actually when I had all my rebuild dramas it didn't throw a code till I revved the sh*t out of my tractor
fairly sure he's be over the moon if it sounds like a tractor at the moment :lol: :lol: :lol: :cheeky: :cheeky: :cheeky:
BorepYano
Re: Fto not firing!
Post by BorepYano »
any update on this?
Nuttsausage
Re: Fto not firing!
BorepYano wrote:any update on this?
haha yeah man I bought a ford laser. It hasn't been touched, I'm going to get someone to look this week probably.b
Re: Fto not firing!
Re: Fto not firing!
*Fixes car issues by buying another car*
I did this once, and the other car is still sitting there 5 years later
Re: Fto not firing!
kiz wrote:*Fixes car issues by buying another car*
Put the KL in the back of the FTO bro.
Re: Fto not firing!
I've done this at least 8 times.
Nuttsausage
Re: Fto not firing!
The lasers going great!
Update on the fto, apparently there was a couple of modules not earthed correctly, causing the coil packs to stop. $350 for labour should be picking it up today..
I'm pretty happy with that..
BorepYano
Re: Fto not firing!
Post by BorepYano »
out of curiosity, did they tell you which ones weren't earthing property?
