gpvr turbo
Re: gpvr turbo
Vectose wrote:Gonna see if I can push it to 18
You are a lunatic, but we always knew that...
azza0666
Re: gpvr turbo
Post by azza0666 »
so there no real point spending the money to turbo the stock engine i may aswell engine swap instead?
Re: gpvr turbo
azza0666 wrote:so there no real point spending the money to turbo the stock engine i may aswell engine swap instead?
Put it this way: everything gets vastly more expensive the less you do yourself (and sometimes expensive even if you do).
Vectose has recently proven that you don't need to engine swap or spend over 10k (far as I'm aware) to crack 200kw, but he has done it well and proper and has an experienced tuner who knows their stuff. You're already struggling for traction even below that figure, and then you've got the gearbox to worry about like in Ben's case. :lol:
If you have deep pockets, then you do this:
http://www.mitsubishi-fto.net/car.html
And if you have endlessly cavernous finances then you chop it up, EVO swap it and make it AWD for mad internet cred points.
Re: gpvr turbo
Dont forget Rob did most of the fabrication himself I think..
Re: gpvr turbo
Daniel2019 wrote:Dont forget Rob did most of the fabrication himself I think..
Exactly. And also made the loom for the ECU. And stripped the engine down. And did all the fitting (pretty sure). Etc, etc...
Re: gpvr turbo
So 10k in parts alone :lol:
f**k that :lol:
Re: gpvr turbo
:lol: Cost me 5k. And that's with a $1200 Haltech + tune and all new parts.
Re: gpvr turbo
And yes, did everything but the head machining myself.
Re: gpvr turbo
Fabrication is the most expensive part though.
azza0666
Re: gpvr turbo
Post by azza0666 »
vr4 engine swap or evo engine swap? which would be better and why looking for around 250HP
azza0666
Re: gpvr turbo
Post by azza0666 »
id be happy to spend 10k on forced induction to get the car i want. nice little turbo fto
Re: gpvr turbo
6A13TT. Tried and tested and heaps of info available.
