- creepymatt zzz.png (5.6 KiB) Viewed 4444 times
Wrecking fto **NOW SOLD**
- bjk
- Totes
- spetz
Re: Wrecking fto
Do you still have the alternator?
Re: Wrecking fto
would be interested in foglights/indicators and their brackets
- getonit
Re: Wrecking fto
I have a Mivec alternator. Couple of bits of plastic missing around the plug but a dab of glue holds the plug in fine.
$50 plus postage if needed if interested.
- spetz
Re: Wrecking fto
Any pics of the damage?
And is it the OEM alternator?
- getonit
Re: Wrecking fto
Yes is an original alternator.
- P1020618.JPG (263.88 KiB) Viewed 4425 times
Re: Wrecking fto
Wonβt be good enough for his lancer
Re: Wrecking fto
Too much weight offset from the missing plastic.
Re: Wrecking fto
Would need a slightly higher spring rate to offset the weight on the drivers side
- spetz
Re: Wrecking fto
Don't be an amateur Sahin, obviously I would re-valve the dampers rather than change springs.
@getonit,
I just have to check what alternator is in my car currently and let you know hopefully in the next couple of days.
@getonit,
Re: Wrecking fto
And do you want the carbon fibre gearstick/stereo surround or the fto gearstick surroundMivec swapped gx wrote: βTue Mar 27, 2018 12:47 pmAll thats sold to a mate pending how much you offer for all of it other than rims and i might consider
Re: Wrecking fto
How much for foglights/indicators and their brackets?
- mezje
Re: Wrecking fto
Code: Select all
Right sides got both broken left is fine if you just want the one side
