Bjs turbo Version R fto
Re: Bjs turbo Version R fto
Nice man! done yet! its perfect!
But to be honest i dont really like the bonnet :\ but that doesnt matter...
- fto-007
yeah im not fussed on it...later on ill paint it the same as the car i tried to get a firerglass one but they didnt make then in that style nor make a standard one in fiberglass that i could do some custom vents in it...the bonnet was to try get some of the heat out :/ still way too hot under there have to buy an aluminum radiator for it, it cools it up to 40% better
Looks so clean
Great job on it!
Great job on it!
- fto-007
getting there slowly made 300hp atw @17psi...spins 3rd @ 100kmh ha ha have to hold on lol....as it didnt make as much power or rev as expected some research was done to find the custom 272/300 cams were never zeroed in....they were zeroed in to the custom cam gears which arent right....so i have to zero the cams in mark TDC on the cam gears and change the timing to the right point... then should produce power to 9K and around 400hp atw on pump!!!!!
I sooo want!!
- spetz
I as well do not like the hood
Once it's painted white it should look much better though
Amazing build, kudos to you man. I've always been advised not to spend too much on my FTO, so I'll be switching cars when my degree is over and I've settled into a better job, but I've always wondered what COULD happen if someone went all out. Thank you, sir, for bringing my dream to life. The car looks and sounds incredible, and I, like everyone else here, can't wait to see the final result. Cheers from far, far away
- fto-007
Thanks man new things to do: ordered new aluminum radiator, ordered $250 worth of exhaust wrap, new thermo fan, new gear box cables, design and make heat duct for the radiator and design and make air box with air duct, modifiy carbon bonnet with a heat duct... photos to come
You're the definition of nuts!fto-007 wrote:Thanks man new things to do: ordered new aluminum radiator, ordered $250 worth of exhaust wrap, new thermo fan, new gear box cables, design and make heat duct for the radiator and design and make air box with air duct, modifiy carbon bonnet with a heat duct... photos to come
- fto-007
ha ha it has a problem with the heat in the engine bay trying everything to get the heat down and get more power
no bonnet! problem solvedfto-007 wrote:ha ha it has a problem with the heat in the engine bay trying everything to get the heat down and get more power
but seriously... your car is amazing and im sure whatever you do it will look good...
- fto-007
new goodies
- fto-007
Front header modified to accomodate the new thicker aluminum radiator, headers, dump, y pipe, screamer fully heat wrapped with DEI exhaust heat wrap, heat sheilds made, new gear box cables, custom perspex air box with air feed all getting there!! took it for a spin the other day in the wet....1,2,3 are useless broke traction in 4th at 180kph
Holy f**k is all i can say!
- ZFL45H1
f**k that 180 braking traction that sh*t is crazy but awesome at the same time
- aza013
- NSW Coordinator
I would have to 2nd that ^^^^^^^^^^^^^^^^ .ZFL45H1 wrote:f**k that 180 braking traction that sh*t is crazy but awesome at the same time
Sounds like a sh*t load of fun.
180 in 4th? I could only hit 180 in my FTO in the top range of 5th!
I mean, I didn't try that....
Build looks awesome though, and I want one!
- fto-007
you have to hang onto the wheel with both hands thats for sure i have hit rev limiter in 5th gear.....i thought i had another gear left, then i was like ok im in 5th time to slow down
- ZFL45H1
that's crazy man how u decided to put that much unusable power in a fwd is insane hahaha but super cool
- fto-007
it started off with a little turbo and not building the engine too a fully built engine with a massive turbo ha ha did get a little out of control
