ADZSKI'S FTO
- bjk
- Totes
Re: ADZSKI's FTO, NATASHA
I'm envious of our neighbours as they've got a flat smooth one. Ours is right next to a tree and therefore probably the roots too. I've been looking at Dwayne's front bar so much but I think I'd have to park on the street, haha.
Update.
i bought some gpx calipers off dwayne (dstocks), not sure if they will need a reco or not
also going to buy some slotted rotors soon.
bought dwaynes front bumper should have it in a week or two. it just has to be made up first
also picked up a new stereo surround!
new leads went on today, put net lug nuts on also. will take a few pics later
Update
ok few things will be happening in the coming week.
firstly still waiting on the front bar to arrive
lately for work (industrial refrigeration mechanic) i have had to spray a couple machines i had to rebuild and make them look pretty and did a rather good job (using proper equipment though) not a spray can if you were wondering
so i thought, as i have access to this equipment im going to spray the new bumper my self to save abit of $$$.
.just purchased fog lights for the new bumper. there the same as the one's Technikhaus used, also im putting 6000k hids in the foggies.
.havent decided on a pacific indicator yet
.also purchasing another set of hids (6000k) for the head lights.
. to the fun bit. in the next day or so im purchasing a samsung galaxy tab 2 gt-p3100, this will be mounted where the head unit is and the head unit will be relocated to the glove box as i want to still be able to access it and use it when need be.
the tricky bit- ive been browsing ebay looking for a head unit extension harness but not had much luck, later this week going to pop down and talk to my auto electrician and see what he suggests.
Seems like everyone is stealing my idea.adzski wrote:. to the fun bit. in the next day or so im purchasing a samsung galaxy tab 2 gt-p3100, this will be mounted where the head unit is and the head unit will be relocated to the glove box as i want to still be able to access it and use it when need be.
You can use any wire to extend the head units wiring, just cut and join.adzski wrote:the tricky bit- ive been browsing ebay looking for a head unit extension harness but not had much luck, later this week going to pop down and talk to my auto electrician and see what he suggests.
Vectose wrote:Seems like everyone is stealing mightycarmods' idea.adzski wrote:. to the fun bit. in the next day or so im purchasing a samsung galaxy tab 2 gt-p3100, this will be mounted where the head unit is and the head unit will be relocated to the glove box as i want to still be able to access it and use it when need be.
I did it before they did.
Vectose wrote: I did it before they did.
Replace "dickhead" with hipster
Was debating wether to post this or a hipster meme.. either way..
f**king hipster
There we go
I fkn despise hipsters.
I also had the idea of doing mine before MCM, Seeing Vectose's pushed me to do it :p
But how dare you copy my fog lights!!! :p
hahaha its just such a great idea vectose hahaha
and as to the wiring harness, so i could just solder a longer piece of wire to each individual wire?
Correct.adzski wrote: and as to the wiring harness, so i could just solder a longer piece of wire to each individual wire?
hahah great minds think alikeTechnikhaus wrote:I also had the idea of doing mine before MCM, Seeing Vectose's pushed me to do it :p
did you get the additional hids for a extra $15?
Vectose wrote:Correct.adzski wrote: and as to the wiring harness, so i could just solder a longer piece of wire to each individual wire?
oh hahah sounds like a piece of cake will most likely start doing it this weekend.
Just make sure you use a thick enough wire for the constant power and ground cables
nah I didn't get the HIDs, I heard they're not that good for fog lights.
But if I did want them, i'd wait until I've got my low beams first, so that I can color match them.
Update.
head unit has been relocated to the glove box, though its only temporary at this point ( still need the galaxy tab 2 and a few other things and glove box needs to be modded so the head unit will sit flush inside, but it works which is the main thing!
bought this to extend the antenna cable
http://www.ebay.com.au/itm/321089678910 ... 1497.l2649
just need to solder back up my remote wire and extended the L and R audio cables then i can begin modding the glove box.
will get some pics for the wiring tonight.
go on, where's the pics?
How annoying was it to move it? haha
