Bjs turbo Version R fto
- fto-007
Re: Bjs turbo Version R fto
Same ones. . See how they go. If they don't pull it up I'll get Mazda mps rear calipers
- fto-007
Modified sump with baffles. Enlarged 1.8 liters
- fto-007
Finishing rear upgrade!! Bit of a mission but got there
So clean!
How come the bigger sump?
Looks great.
I'd assume it was modded so that it fixes the issue with oil starvation when mivec kicks in?...destinationtoby wrote:So clean!
- fto-007
I'm going to track it later on. I wanted the bigger capacity so there would be no chance of it oil starvation on the track
- fto-007
Cause it revs so hard and the g forces when cornering you want as much oil in the sump as possible. Don't want to destroy a 15k engine
- aza013
- NSW Coordinator
Dry sump setup would be the way to go .
But still a great job .
- fto-007
Didn't want a dry sump. a lot more work and money!!! Maybe if it was a 1000hp full track car that was stripped. .
- aza013
- NSW Coordinator
Fair call.
Every time you post up updates the car just gets better an better .
- fto-007
Almost finished!!!
- aza013
- NSW Coordinator
you will never finish it, there will always be more to do ( or I should say more you would like to do ie. MORE POWER ) .
- fto-007
It's as modified as it can be so there's no getting anymore power. I think 400 horse power at the wheels is enough power. Next thing will be the drive train
- rock_it
There is always a "next thing will be"
- fto-007
made 355hp atw on 20 psi. . . with overheating issues on the dyno. Next tune with e85
- fto-007
Side skirts moulded and fitted to the car. car has been widened 20mm front and rear, can fit 9.5 inch rims all round now
Dman, very nice!
And some decent numbers there too!
- fto-007
I was a little disappointed. . . . I was hoping for 400 hp on pump fuel
You'll just have to do more work to it :p
