silverGPXs Ride
Re: silverGPXs Ride
#needsmorepics
#Lowlyfeisaweome
#penisbutter
#Lowlyfeisaweome
#penisbutter
Re: silverGPXs Ride
Well this got done, bar giving the interior bits off to be reupholstered (He went away on holidays).silverGPX wrote:Well seeing as i have finished doing the rear end i will start working on the interior and engine.
This weekend i plan to:
-Install Error Code free ABS ECU (Already cleaned and installed new ABS Sensors)
-Give My center console, handbrake lever and Gear Gaitor off to my work collegue (Upholsterer) to get made up and covered in new leather
-Drain Sump - fill oil cooler and system with new Penrite HPR Full Syn 10W along with new Drift Oilfilter
-Reinstall Radiator, Replace Coolant Sensor from Shtuart, fill with coolant
- Start Car
- Bleed Brakes/Adjust handbrake Cable
Got a few other things done.
-Sahin fitted exhaust gaskets
-Plugged Vacuum gauge into T-Piece, this also solved the engine light flashing as the line being off messed with the map sensor
-Found a coolant leak and fixed it
-Fitted stereo, tuned it
-Fitted Cigarette lighter and bulb with fixed up loom
-Adjusted coilovers back to close to -1 camber on front
-Limter bashed every gear in the garage while up on stands
-Secured fusebox back in
-Fitted and wired in Davies Craig Fan all legit and sh*t
- Shhtuart
Re: silverGPXs Ride
silverGPX wrote:Registered it
Re: silverGPXs Ride
-Wheel alignment done
-Car cleaned inside and out
-Filled fuel tank to top
-Fitted Custom intake pipe and had a reducer made up for genuine HKS mushroom Pod
-Drove everywhere
-New battery terminals - Cleaned up earths
-Drove everywhere
Re: silverGPXs Ride
Some Random Pictures
Re: silverGPXs Ride
Lol those wheels are somewhat classy
Rear looks pretty complete
good effort
Re: silverGPXs Ride
Lol yeah off an S14, still got the nissan centers
So pplz, I am buying rims on Tuesday night but i cannot decide on Rota P45R's or Rota Grid R.
Either Set will be in Gloss black and 17" x 9" +25
Opinions?
P45R Grid R
Opinions?
P45R Grid R
Re: silverGPXs Ride
Grid R in my opinion. Looks clean (literally)
Re: silverGPXs Ride
I like grids myself, they're what Nick's got on his FTO, and looks awesome
Re: silverGPXs Ride
So in other words, 5 spoke or 6?
- vanadinite
Re: silverGPXs Ride
6 spoke, Rota Grid R
Re: silverGPXs Ride
Some lightweight Enkei's PF01!
Re: silverGPXs Ride
Lightweight would be cool, but budget is $1000 max for rims.
- shadowarrior
- Tightarse
Re: silverGPXs Ride
Lol!! Exactly what I was thinking.Bennoz wrote:So in other words, 5 spoke or 6?
- ObsidianRadio
Re: silverGPXs Ride
I'd go the grids.
Re: silverGPXs Ride
I'd be wary of buying grids.... The paint is pretty crap.
Nick's onto his second set, and two days after getting them they already have paint chipping.
Re: silverGPXs Ride
First set were reluctantly replaced under warranty by Rota NZ, With this set coming with NO warranty.
Re: silverGPXs Ride
If they have poke with stretch they will chip from the stuff being shot out from the back wheels on the lip anyway.
