I washed my cars. Then got hailed on. Again. In spring. FML
I put my rims on :cheeky:
Installed a short shifter :cheeky:
Feels amazing.
Vectose wrote:Installed a short shifter :cheeky:
Feels amazing.
Show us ya shaft
Feels amazing.
Show us ya shaft
Is it worth $50?
Hell yes it's worth $50. But does require a bit of metal grinding to widen the hole on the bracket. It works without enlarging the hole but the shaft hits on it and is a bit harder/notchier to get in to gear. Will post up pics soon.
Link to the shifter?
Did it off-set the shifter at all?
Vectose wrote:Hell yes it's worth $50. But does require a bit of metal grinding to widen the hole on the bracket. It works without enlarging the hole but the shaft hits on it and is a bit harder/notchier to get in to gear. Will post up pics soon.
Fuckin virgins
Standard Throw 1st to 2nd
Short Shifter Throw
Stock shifter in Neutral
Short shifter in Neutral
Comparison
Short shifter also has the same curve as the stock shifter
14 washers per bolt required, total of 42 washers :lol:
I will get a photo of the part that needs to be grinded tomorrow. (Haven't grinded it yet)
Why not buy a spacer over using the washers.
Hell, even a metal works could grind you off a piece. or go cheap and buy a nut larger than the bolt to which you thread through.
lol, nice pics.
Because I wanted to get it done and I had a box of washers laying around.
Vectose wrote:Because I wanted to get it done and I had a box of washers laying around.
Fair call. :lol:
I got the same USB lighter thing as you lol
I don't use mine :lol:
Vectose wrote:I don't use mine :lol:
That's because you don't have a GF :troll:
But I do have a girlfriend :lol:
Vectose wrote:But I do have a girlfriend :lol:
What's his name?
What's his name?
His name is FTO :cheeky:
:roll:
phunkydude
Post by phunkydude »
