$2.33 a litre for 98
- aza013
- NSW Coordinator
sh*t! I filled the car up today @ $1.55 for 98Technikhaus wrote:$2.33 a litre for 98![]()
I haven't filled up for 2 weeks :3
- aza013
- NSW Coordinator
Lol. I have not taken the car out for over a month, so I had to do a once over on it fuel it up and charge the battery
for the bonfire?
- aza013
- NSW Coordinator
silver carbon wrapped the rest of the front bar
replaced a tie rod end, ball joint and control arm bush.
waiting for some help from phil or benozz on how to put it back in.
then will do all the same on the other side tomoro hopefully with enough time to go for a wheel alignment
Finally finished off the bike.
Couldnt fit in the shift kit in the end as the frame was just way too small - and the bigger frames arent solid steel like they used to be. Id be chasing down a big steel frame for years before i found one suitable.
Probably shouldnt be going over 50 anyway
Just gotta get some fuel and start her up - pics are are on FB. Hope it goes as hard as it looks
Vectose helped me get the loom all set up in the GR. ECU is right to go in and apart from that there's not much else I can do until I have money for the engine work.
peeled off sticker bomb, along with a fair bit of paint
looks delightfull
Did photography for the Otago rally this weekend, used $170 worth of fuel, and about 700-800KM of driving, didn't get too dirty :p
- bjk
- Totes
destinationtoby wrote:peeled off sticker bomb, along with a fair bit of paintlooks delightfull
+1 Gen X point.
- KyzPride
Daddy and i changed front shocks and springs yesterday... 20mm lower
no more noisy shock
no more noisy shock
Did you check the bearing and is that fine?Astron_Boy wrote:Checked the fluids.
They're fine.
dstocks wrote:Did you check the bearing and is that fine?Astron_Boy wrote:Checked the fluids.
They're fine.
See, you just arent prioritising properly
- bjk
- Totes
I thought that was a characteristic of Gen Y.dstocks wrote:See, you just arent prioritising properly
In this case, I'm waiting for a Gen Y so I can fix ours.
Hopefully in the coming weeks.
Still haven't got the bloody towbar yet from the pricks at the work shop.
Talk about prioritise. 3 damn weeks...
