I got my drivers seat re-foamed by an auto trimmer today. The base and also extra padding in the back.
I still have to bolt it back in yet.
Hopefully no more side bar sticking into my leg.
Cost = $150
Cost = $150
Going for the Commonwhore effect ahh?destinationtoby wrote:Changed my back wheels
Business tyres up front.
Just fitted my refurbed seat, sooooooo cumfy
PicsPHIL069 wrote:Just fitted my refurbed seat, sooooooo cumfy
Why?silverGPX wrote:PicsPHIL069 wrote:Just fitted my refurbed seat, sooooooo cumfy
It's a stock seat professionally re-foamed.
Haven't you seen a stock seat before
Astron_Boy wrote:Going for the Commonwhore effect ahh?destinationtoby wrote:Changed my back wheels
comin from the guy that drives around with a sign that reads "Astron Boy" on his dash.
just going to get new tyres on the other ones actually, thought id wear these out abit before i scrap em.
- XenaP
I'm jellyPHIL069 wrote:Just fitted my refurbed seat, sooooooo cumfy
I'm waiting until I can afford to get them recovered as well as padded so at the moment I'm putting up with the dreaded metal bar in my leg.
AND NO EFA ON THAT SENTENCE!!!!
- shadowarrior
- Tightarse
damnit!!!XenaP wrote: AND NO EFA ON THAT SENTENCE!!!!![]()
hit 200 000km
- XenaP
Love your sticker bombed surround
Picked up the improved towbar.
Installing tomorrow morn.
Can I borrow it to drag my container to SAAstron_Boy wrote:Picked up the improved towbar.
Sure.PHIL069 wrote:Can I borrow it to drag my container to SAAstron_Boy wrote:Picked up the improved towbar.
Can pick it up in the Hunter on Sunday afternoon.
- payaya
Where you have those stands under? Looks like you are jacking it from the radiator support beam?destinationtoby wrote:silver carbon wrapped the rest of the front bar
replaced a tie rod end, ball joint and control arm bush.
waiting for some help from phil or benozz on how to put it back in.
then will do all the same on the other side tomoro hopefully with enough time to go for a wheel alignment
Bowtae installed.
For some reason, despite being perfectly square, it's still dipping.
Are the rear frame arms of the FTO on a slope or something?
Will just get the tongue bent to shape as the welding and extra brace were spot on.
- IMG_2413.jpg (94.42 KiB) Viewed 223 times
payaya wrote:Where you have those stands under? Looks like you are jacking it from the radiator support beam?destinationtoby wrote:silver carbon wrapped the rest of the front bar
Probably would of pushed the radiator thru the top of the car, if that was the case
He didn't mean by the actual radiator you retard!destinationtoby wrote:payaya wrote:Where you have those stands under? Looks like you are jacking it from the radiator support beam?destinationtoby wrote:silver carbon wrapped the rest of the front bar
Radiator support beam idiot. Try jackin you car from it and see what happens...Sahin wrote:He didn't mean by the actual radiator you retard!destinationtoby wrote:payaya wrote:Where you have those stands under? Looks like you are jacking it from the radiator support beam?destinationtoby wrote:silver carbon wrapped the rest of the front bar
