I washed mine today.
Tough job.
zuihoujueding
Post by zuihoujueding »
Replaced front and rear engine mounts
replaced front drop links
Clinking noise when moving off still exists!!!! :x
Went saw a bunch of Asian guys to wash my car :lol: Best 35 dorrah "Deluxe" wash evAr! :cheers:
Yesterday changed both gearbox & engine oils.
I never knew how badly pounded they got with a turbo setup :o My oil has only done 5,000kms & it came
out blacker than Ernie Dingos arse & with the consistence of water. Gearbox oil was equally pounded,
also like water when it came out... and this is the second time I've changed both oils in the 10,000kms
I've had the car back. Different products used each time too :|
Put on slam panel.
What I didn't do was:
GET MY STEERING WHEEL OFF :evil:
Sweep
Post by Sweep »
I had my rear bar resprayed :alien:
And that slam panel looks good!
Nothing done to the car yet but I ordered these for the car :D
The numbers will be 013 (not 27 like in the pic), and the name A.SIMS (not Gen sport)
and looking into getting this, made from CF :D
Sweep
Post by Sweep »
Nice Looking forward to seeing the fished pics already :mrgreen:
woot! didnt know u had kers aza???!!!
FTW
Thanks sweep.
Nice aza, thought that would be too ricey for you :lol:
brad_gpx
Post by brad_gpx »
last night i change my flat tyre
was fun in the freezing cold
dr390
Post by dr390 »
finally installed my subs :)
Tell me when i stop
Uploaded with ImageShack.us
zuihoujueding
window guides replaced. one more annoying noise gone!!!
Put in new ECU Piggy and new Suzuki Sport grill in FTW!:cheers:
whachu think???
next project: Lightened UD pulley and exhaust!
I resprayed my condensor black again, sanded and polished the powersteering cooler pipe, also painted the framework underneath and around the condensor, looks so clean through the bumper hole now.
Oh and i put some black mesh in. Pics tommorow :)
Blastard all the cobwebs out of the black FTO :twisted: which had to be jump started cos I got lazy and forgot to turn it on for a few weeks :/ .. washed/cleaned my car.
Looks sweeeeeett!! Schumie
FTO-BOY
Post by FTO-BOY »
zuihoujueding wrote:my mechanic did
1) VRS kit service
2) machine the heads and dip in acid bath
3) clean out all sludge, The amount of sludge at the cam area is unbelievable!
4) replace 8.5mm magnecor ignition coils
5) replace NGK iridium IX sparkies
6) Changed Nulon gearbox oil, added Nulon G70
7) Flush with Liquimoly Engine detox and change to Valvoline engine armour 10W-40 engine oil
8) change coolant.
9) replace alternator pulley and crank pulley with aluminum ones.
10) clean and seal reseal oil sump.
11) replace head bolts and some seals which are not included in the VRS kit
The mechanic found out that my timing belt is actually miss aligned by one tooth.
Results: Now the car sounds totally different. so much eager and louder than ever. Noticably feels more responsive and will update if the fuel consumtion have imrpoved.
Hey zuihou how much did this all cost and where did you have it done? I want to do this also.
Today with the help of Matt (silver_gpx) & My lady, (kustoms_GF)
We did...
1) Swap front bar over to stock so I have parkers & it's not to low for the inspection :lol:
2) Sanded down the lights, first try so it's so-so.
3) Spray the speaker covers black.
4) Put new mesh in the Factory T's front bar.
5) Took the black car for a spin around the block.
6) Sat around talking.
So yeah. Preety productive for me... Heres some pics!
Nice. Whaddya doin' with the old front bar?
Well it's gotta go through the Written off inspection so i gotta get it towed to the place. Since It's unregistered.
And I need parkers and couldn't be bothered installing them so I thought id just put the prefacelift bar on so it has the pods with the parkers.
Or do you mean, what are we doing with the facelift factory t's? It's going back on, this blue bar isn't ours its yangs.
