payaya wrote:Valandis91 wrote:payaya wrote:Valandis91 wrote:had nothing to do really today so thought i'd finally do a 0-100 time using the datalogging off the emanage.
Remember this car isnt tuned yet. Is tiptronic. Just not running right.
anyways. the first run i did. no launch did 0-100.... 6.9 seconds. dodgy slipping gear change from 1st to 2nd though
the tried again with loading the torque convertor to 2000rpm.
got 0-100 in 5.2 seconds
with a quick good solid gear change as well.
i didnt realise it was that fast. im having difficulty finding the best way to change gears.....
if i keep my foot planted the gearbox sometimes slips due to the torque.
then if i lift off and plant it when it changes gear the wheels spin and i get major torque steer then the revs drop
due to the much larger profile on the non mivec cams it seems to struggle a bit due to being rich and ignition timing being off. but once mivec kicks in... wow. as mivec has only been increased a small amount.
hopefully get it tuned in the coming weeks. will keep updated.
So in basic terms you get an extra to 100km/h quicker by stalling to 2000rpm? That means your car spends 1.7 seconds to get from idle to 2000rpm. Surely going by that you can determine that measuring tool your using is wrong!
Good times but highly unlikely.
why are you so skeptical? it makes sense cos my car struggles a bit down low cos it needs a lot of timing put into it cos the non mivec cams are a lot more aggressive than stock so to the car moving makes sense.
that measuring tool im using is data straight from the ECU...
how could that be wrong? its information straight from the ecu that is then converrted in graphs using the emanage software.
no one else has done this to a fto so how do you or anyone on here know what its capable of?
Skeptical? I just find it hard to believe your car does 5.1 seconds to 0-100 in an auto and is shifting bad! That would put you in the 13's! Also your dyno result tends to go against you as well.
If you wan't me to believe you go to the strip and post your time slips. Even the turbo boys would be happy with your claimed 0-100 times.
the time i did it in 5.2 secs was a really quick shift, like unexpectedly quick.
i will go to the drag strip eventually once it is tuned.
speaking of tuning....
THIS FRIDAY NIGHT FROM 6PM MY CAR WILL BE GETTING TUNED
its finally getting a full tune from GT Garage. Will finally be running the way it deserves and maybe the FPR might even be set not just an obstruction in the fuel line.
but im really looking forward to this.
will try and get a couple of vids on the dyno.
the sound this things makes is amazing.
i dont even listen to music much anymore
fingers crossed we dont come across any errors and its all smooth
