DIY: Changing lower engine mounts
- payaya
Re: DIY: Changing lower engine mounts
I just got a rear mount from Repco for 55 bucks. Not sure how it will go but!
Cant believe but the intermittent vibration I had at idle is not gone!! I just matched up a front mount and it's 70 bucks from Repco.
So 55 bucks for rear mount and 70 bucks for front mount.
- vandit
Found something while shopping for some parts for my 34
Tip front mount: MR131296
Tip rear mount: MR223674
The tip front engine mounts are EXACTLY the same (same part number) as the Lancer/Mirage CE / DEA 1.5 model ones
Front mounts from autobarn are 60bucks
Front ones i found at Lees Spare parts Springwood (brissy)
They are 95 bucks
Hope this helps .. Mitshu wants 140 for front and 195 for rears.. and its 3 weeks ETA from japland
They are 95 bucks
- vandit
EDIT from Above
tip front mount: MR131296
rear ones i found at Lees Spare parts Springwood (brissy)
They are 95 bucks
Hope this helps .. Mitshu wants 140 for front and 195 for rears.. and its 3 weeks ETA from japland[/quote]
They are 95 bucks
- payaya
Repco sell the rear mounts for 55. Exactly the same as the tip version. If your side mounts are sagged take care of them first. If you want the rear tip mount kelpro part number I'll try dig it up.
- payaya
Also if you want a cheap fix to your mounts before buying new ones get sikaflex sealant 252 from bunnings fill in the mount let it dry for couple of days and put them back in. Worked a treat with my old mounts.
Vibration disappeared under load.
- vandit
Sweet thanks for that I'd rather get new ones since they are cheap
- payaya
Sweet ill try grab it.Your obviously getting vibration at idle? Did wonders for me. It's a common size and Repco stock them without order I'll dig it up tomorrow. Its a kelpro part number.
- payaya
Rear auto mount part number is mt8419. I think fronts are 90. Take a sample in they match it up.
- vandit
Hey bid I changed the mount my rear was shot ! Thanks for the part numbers And help bad news is the vibration on load is there checked it with transmission specialist they said it's the box spindle it's bent 400 to fix ![Sad :(](./images/smilies/icon_sad.gif)
- payaya
Check your front mount? Sika flex your old rear mount with sikaflex and same with the front and for me my vibration under load disappeared.
CBF reading the whole thread, was that solid centres or the tip variety?payaya wrote:I just got a rear mount from Repco for 55 bucks. Not sure how it will go but!
- payaya
Tip mate. But repco have a kelpro trade book and no doubt will be able to see which has a solid core.
f**king none of them. Went to both Repco & Bursons today, even had Bursons engine mount rep come down & none of them could supply a solid centre. He even argued that I dont need a solid centrepayaya wrote:Tip mate. But repco have a kelpro trade book and no doubt will be able to see which has a solid core.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
- -Nighthawk-
Is there a place where I can buy the full mounts from? (besides Camskill)
Don't have a press and would rather get the whole unit.
Cheers
Cheers
Yeah the ones Bursons had were from http://www.transgold.com.au/home.html & they were whole mounts. $120 for both I thought was a real good price. Tip only though.
- spetz
How do non-OEM mounts compare though?
Couldn't tell you. I've only used genuine, Ralliart & Poly.
- spetz
Do you notice any difference besides NVH?
- payaya
Mackay have a larger selection of mounts which is also through bursons.
- payaya
They are exactly the same as the original mounts.spetz wrote:How do non-OEM mounts compare though?
