Nvr2lows 6a13 conversATION WITH BEN ABOUT HIS CONVERSION
- nvr2low
oh and another thing is that the wires that go to the white plugs are taped togther with the green plugs.
They both come inside into the car so they may be for the tip ecu or gauges maybe.
Ben did yours have the white plugs in you loom.
My loom is a complete loom it has all the battery terminals and everything
- nvr2low
- RichardB
I got mine from http://www.xtremeclutch.com.au
and its held 500bhp all year.
The part numbers were
TB32003 - thrust bearing
VM123110MS - clutch
DM12320201DBS - clutch cover
VM123110MS - clutch
- nvr2low
another update
Hey guys mounted my front mount onto the car looks sweet and I also made up the piping from the intercooler to the throttle body.
Just waiting on flywheel and clutch then I will figure out how to do the front turbo actuator as the gearbox will be then bolted on so I can see were the actuator has 2 sit.
Then I will drop my motor out and then drop the 6a13 in and see how many pipes I gotta move and see if it hits the steering rack likes ben
- nvr2low
ok clutch is on the way got a craker of a deal to got it down from 560 to 420 and should be here next week. I have decided to bite the bulit and take my car off the road next sat and pull the motor out needs some answers though.
Hey ben did you take your motor out with the gearbox attached and did you drop it out or lift it out the top.
After all the engine and everything is out and I start moving lines ben did you get somebody to do it for you or you do it urself.
How far did you have to move each line I read you said aircon powersteering and brake.
I am guessing your 6a12 wiring loom is still in the car.
I also have to put my manual stuff in so might take me a few days
Thanks guys any help would be good
- vipfto
if you have hoist drop it out with box mate....nvr2low wrote: ok clutch is on the way got a craker of a deal to got it down from 560 to 420 and should be here next week. I have decided to bite the bulit and take my car off the road next sat and pull the motor out needs some answers though.
if not remove box and take out from top carefully
You gotta read my thread more carefully matenvr2low wrote: ok clutch is on the way got a craker of a deal to got it down from 560 to 420 and should be here next week. I have decided to bite the bulit and take my car off the road next sat and pull the motor out needs some answers though.
Engine & gearbox is easiest dropped out from beneath whole.
Im not moving any lines, Im moving the turbo
6A12 loom is out, 6A13 is in. You need to drop out half the air con stuff from behind the glove box to be able to do it.
- nvr2low
ok man so the 6a12 loom was taken out did this include all the plugs to the dash and everything or just the engine loom as doesn't the 6a13 loom have to be wired into all the dash buddy. I am sorry about this I aint the best mechanic lol.
But I swear I read that u moved your brake lines and stuff man.
With the aircon stuff behind the glove box do u just have to move it all so the wires come out man. My main problem is about the wiring loom what I have to leave in the car so the sparky can wire the 6a13 loom in this is were I gt confused
Thanks ben
Thanks ben
Its just the engine loom you remove. It comes into the cabin under the air con stuff & plugs into the ECU which is mounted up on the side of the car under the air con gear. You pull the CU out & pull the loom all the way out from the engine bay. Its about a metre & a half worth of wire & plugs. As to how it all wires backup, dunno, thats for my sparky to work out! ![laughing :lol:](./images/smilies/icon_lol.gif)
- nvr2low
ok kool man thanks. It just with my 6a13 loom it has green plugs which is for the ecu then all these white plugs which are taped with the ecu plugs and I was just wondering if the 6a12 loom as any other plugs that plug in any were else other than the ecu inside the car as that is what my 6a13 loom looks like it has
- nvr2low
- vipfto
dont mean to be rude mate but are you doing this yourself? without knowing much about a turbo engine and never doing an engine swap beforenvr2low wrote:ok so i am guessing that this is the exhuast that comes off the turbo mmm i am going to see if maybe we could make a new one up would that work oh but it also hits the firewall
![Shocked 8O](./images/smilies/icon_eek.gif)
if so youve got some big balls and i take my hat off to ya
![Cool 8)](./images/smilies/icon_cool.gif)
