Are you trying to tell us that the sump doesn't spin? I'M DEVASTATED AT THIS. D:Bennoz wrote:Flywheel is not connected to the sump mate. Think about it, the flywheel spins...
Daniel's Rookie DIY FTO Build!
- ObsidianRadio
Re: Daniel's Rookie DIY Engine Reco!
Wow lol
HAHA I know that much. But what im saying is the housing seems to share bolts on the bottom.Bennoz wrote:Flywheel is not connected to the sump mate. Think about it, the flywheel spins...
After undoing the bolts (I think there was 2 in there, but about 5 spots for them) on the flywheel, how does the flywheel come out? Either its seized on or Im missing a bolt or something
You don't even have a fly wheel on that engine!
Omg lol... Hahahahahahahahahahahahahahha
Akys told me to remove the flywheel! EVERYBODY STOP f**king WITH MY BRAIN IM TRYING TO LEARNPHIL069 wrote:You don't even have a fly wheel on that engine!
To me it looks like the adaptor plate that you have there, the flywheel would bolt to those 7 holes.
Give us a better pic of the area
Please note the title - Daniel's ROOKIE DIY Engine Reco!. Key word being rookie.PHIL069 wrote:To me it looks like the adaptor plate that you have there, the flywheel would bolt to those 7 holes.
Seriously facepalming so hard right now.
I haven't striped one of these engines either.
No one that has done it before noticed and told you
Hey Daniel you goto learn somehow, do you have the workshop manuals.
Mainly this one.......http://ftoaustralia.com/downloads/engine_manual.zip
Yeah most of this sh*t ive never seen before. I do have that manual, it just never occured to me that there was no flywheel in there because Akys told me to take the flywheel out before I put it on the stand, and knowing as little as I do, I tried to oblige..PHIL069 wrote:^^^ ^^^
But anyway, up on the stand tomorrow
- Shane001
Yeah do yourself a favour, download a print the manuals. Will save on face palms
With or without the manuals (I do have them ) there will be plenty of facepalming over the duration of this attempted re-coShane001 wrote:
Day 1 facepalm count - 3
Thanks DanielDaniel2019 wrote:With or without the manuals (I do have them ) there will be plenty of facepalming and beer giving over the duration of this attempted re-co
Day 1 Beer count - 1 case + 1 bottle Jim Beam to Phil
Beers for anyone who provides actual help in this thread for the bonfire. Unlike some people who are simply laughing at my inexperience sahinPHIL069 wrote:Thanks DanielDaniel2019 wrote:With or without the manuals (I do have them ) there will be plenty of facepalming and beer giving over the duration of this attempted re-co
- Shane001
Engine stand pics;
The top 2 mount points are threaded holes, the bottom/side points are not, as you can see from the pics I'm using a through bolt secured with a nut.
Use high tensile bolts of the correct length, do not use cheapy Bunnings bolts.
Use washers as I have so the bolt heads tighten up square.
HTH
HTH
What size are the bolts youre using? About 110mm in length?Shane001 wrote:Engine stand pics;
HTH
- Shane001
Don't know and it will depend on your stand anyway, so measure emDaniel2019 wrote: What size are the bolts youre using? About 110mm in length?
Hey Shane, you don't have a flywheel on that engine either.
- Shane001
Yeah I know, I had to angle grind the c**t off as I couldn't get that sump bolt undone ....PHIL069 wrote:Hey Shane, you don't have a flywheel on that engine either.
True. I measured it this arvo its about 100mm in total needed. So I should be using about 110mm, correct?Shane001 wrote:Don't know and it will depend on your stand anyway, so measure emDaniel2019 wrote: What size are the bolts youre using? About 110mm in length?
