FS SYD - Complete GPX Manual Conversion SOLD
Re: FS SYD - Complete GPX Manual Conversion
First you boil the water, then you drop in the crab.
I maintain.
I maintain.
You CAN use a GR manual box on a MIVEC engine and vice-versa.
There is no difference between manual and auto ECU's. The only difference is between Non-Mivec and Mivec ECU's
Auto FTO's have a separate ECU for the auto box.
- Shane001
I'm sure you can use it but I'm guessing the driveshafts will be different?Vectose wrote:You CAN use a GR manual box on a MIVEC engine and vice-versa.
We know the gearing is different. Are there any other differences? I'm thinking clutch, flywheel?
Everything else is the same. As long as you have the driveshafts to match the box, you're good to go.
Yup. The GR box also suffers from the 'It could be 25 spline, it could be 27!' dilemma same as GPX as well
- HeRo
Oh okay,
I have a GP 4spd and the parts my shop has to offer is a 5spd manual box + ECU from a GR fto.
What I now gather from this conversation is that I can use the GR gearbox but remain to use my own ECU?
is this fair to say? .__."
Correct. As long as you have the correct driveshafts.
- Shane001
Also happy to split this up if someone wants the gearbox only, say $500 ono.
- Shane001
Bump. Price drops and also now includes a full set of mounts.
- Shane001
Bump. Turns out I made a big mistake on the kms on this gearbox. I came across the pic of the instrument cluster for the half cut this came out of, don't know where I got 90K kms from, the halfcut only had 76K on it lol!
f**king Corey got a bargain on that engine
- Corey95
Lucky meShane001 wrote:Bump. Turns out I made a big mistake on the kms on this gearbox. I came across the pic of the instrument cluster for the half cut this came out of, don't know where I got 90K kms from, the halfcut only had 76K on it lol!
Wow that's a fresh box
- Shane001
gone to a good home thoughCorey95 wrote:Lucky meShane001 wrote:Bump. Turns out I made a big mistake on the kms on this gearbox. I came across the pic of the instrument cluster for the half cut this came out of, don't know where I got 90K kms from, the halfcut only had 76K on it lol!
- Shane001
$750 FFS someone come buy my gearbox
Honestly I'm shocked it hasn't sold.
These things barely hang about, and yet you can't move yours.
- Shane001
Same, and low kms also...Astron_Boy wrote:Honestly I'm shocked it hasn't sold.
Because the only reason you'd buy it is if you had a fucked gearbox, if it had an LSD it would of sold by now for sure lol
Go back about a year however to a time when all auto owners wanted a manual conversion.
- bjk
- Totes
I'm going to be the bastard that says "If this is still around in x amount of time..."
Any idea how much everything there would weigh? Dimensions of the longest things?
Would it fit in the boot of an FTO?
- Shane001
Can't see why notbjk wrote: Would it fit in the boot of an FTO?
