Fine, fine. I'll race you... but we have to stick to speed limits.PHIL069 wrote:A race is a raceDaniel2019 wrote:That's unfair, I can only do 100km/h!
Let's be responsible and just compare dyno figures.
I'm hoping for 140kw on a good dayand you said race.
You challenged so I get to choose![]()
Dyno is no race
Keeping traction in a FWD
Re: Keeping traction in a FWD
- bjk
- Totes
True. The headwork has got to be worth the fact that his engine has only just recently done 100,000 kms. How much is the haltech you're looking at?Daniel2019 wrote:Well, if I aim high then there's always potential, but if I aim for a mediocre 120kw then I'm not going to get anywhere.
If dstocks can push 135+ with just an intake, exhaust and haltech (I think that was all?) then surely if I go with a bigger TB and some internal work as well as the zorst, intake and haltech then I think 140 is realistic.
Yeah sure I willDaniel2019 wrote:Fine, fine. I'll race you... but we have to stick to speed limits.PHIL069 wrote:A race is a raceDaniel2019 wrote:That's unfair, I can only do 100km/h!
Dyno is no race
Looked at Aza's sig lately?Daniel2019 wrote:Well, if I aim high then there's always potential, but if I aim for a mediocre 120kw then I'm not going to get anywhere.
And I believe Dwayne was at 133kw.
Haven't looked into anything ECU related yet, I'm just trying to get the bastard running first.bjk wrote:True. The headwork has got to be worth the fact that his engine has only just recently done 100,000 kms. How much is the haltech you're looking at?Daniel2019 wrote:Well, if I aim high then there's always potential, but if I aim for a mediocre 120kw then I'm not going to get anywhere.
Decided haltech because it seems to be fairly popular and give some decent gains. Aza and dstocks have proven this.
- bjk
- Totes
Keep us posted, you'll likely get there before I will.Daniel2019 wrote:Haven't looked into anything ECU related yet, I'm just trying to get the bastard running first.bjk wrote:True. The headwork has got to be worth the fact that his engine has only just recently done 100,000 kms. How much is the haltech you're looking at?Daniel2019 wrote:Well, if I aim high then there's always potential, but if I aim for a mediocre 120kw then I'm not going to get anywhere.
I have, but wasn't that with the track exhaust?Vectose wrote:Looked at Aza's sig lately?Daniel2019 wrote:Well, if I aim high then there's always potential, but if I aim for a mediocre 120kw then I'm not going to get anywhere.
Still, 133 with just a tune, exhaust and intake. Surely with ported heads and a bigger TB fresh after a rebuild would make 140 realistic.
phunkydude wrote: For reference, aza for his gpvr fto (lighter than gpx) to 137kws atw
with,
-port and polished
-port matched
-compression bumped up a little
-cold air intake + ram pipe
-de-cat / straight flow pipe
-haltech management tuned
Yep. Still, I'm aiming for 140. I think it's realistic.
Also wasn't that with stock headers?
140 is the goal! Aim high!
But nah, I am aiming for a similar number. Will try and get the best I can, not setting goals only to be disappointed.
- bjk
- Totes
Could always suck it up and buy one new.
Puns, yeah!
Puns, yeah!
I will be happy with 135. I figure the higher I am the higher I'll achieve. If 125 is the goal then its limited.
Wouldn't give you 140. They do 147kw at the flywheel. The figures that we're talking about are ATW figures, not flywheel/crank.bjk wrote:Could always suck it up and buy one new.
Puns, yeah!
- bjk
- Totes
I meant the UAS pipe.Daniel2019 wrote:Wouldn't give you 140. They do 147kw at the flywheel. The figures that we're talking about are ATW figures, not flywheel/crank.bjk wrote:Could always suck it up and buy one new.
Puns, yeah!
Hence the pun.
Don't make me explain it!
Also need to get enough people interested in it so they actually make them.
My bad, I thought you meant a new FTO.. Was kindabjk wrote:I meant the UAS pipe.Daniel2019 wrote:Wouldn't give you 140. They do 147kw at the flywheel. The figures that we're talking about are ATW figures, not flywheel/crank.bjk wrote:Could always suck it up and buy one new.
Puns, yeah!
Hence the pun.
ARC chamber would also work. Or stainless intake like fto-007 has, or something similar.
- bjk
- Totes
I emailed them about getting them made separately, but I didn't seem to get the impression they were currently out of stock. Just that if it was for parts of the kit then they'd need a group. I could be wrong though.Vectose wrote:Also need to get enough people interested in it so they actually make them.
Don't worry Daniel, it's just because you guys are commenting too fast.
Been tested.
Whale d*ck is the king of intake pipes.
You can't say that around Vectose....You are about to get a lectureDaniel2019 wrote:ARC chamber would also work. Or stainless intake like fto-007 has, or something similar.
EDIT: Oh crap my warning was 1 min too late
- bjk
- Totes
too late.PHIL069 wrote:You can't say that around Vectose....You are about to get a lectureDaniel2019 wrote:ARC chamber would also work. Or stainless intake like fto-007 has, or something similar.
don't you get the screen that says someone has commented before you?
