engine mods what next ?
Depends what you want your forged pistons for?
With that list, theres no point of getting them.
If you go for forced induction then deffinately go the forged route, because you can increase more boost. Why spend $3600 for forged pistons (pretty expensive quote) when you won't get anything out of them!
- FTO338
I agree, i wouldn't be bother with foggie, as you won't find any different in N/A. It might make you feel better knowing you have strengten internal every time you give it a "go" but thats about the only benifit with foggies in N/A.
All you guys looking for more horsies, stop looking at price lists start calling mechanics & machine shops.
If I was going further with my motor, I'd be pulling the heads off, getting oversize valves put in, having porting work done, looking to have some heavy duty valve springs put it. Also look to increase compression either by decking the head... just look out for valves belting the pistons. Might be looking at incresing the valve scallop size in the pistons.
Your head does the hard work on your motor. Big gains (for NA motors) can be acheived with headwork - its not always a 'blueprinted' process as such. See a good mechnic / machinist and tell them to get creative.
As mentioned - forged internal are wasted on FTO unless they are blown.
- FTO338
Agree Ben, but lots of ppl will & do look at Gain Vs Money. And N/A isn't that great with that ratio.
I know... just that a lot of people like spetz have hit the end of the line with the bolt ons... there's nothing left to do in that regard & seeing as they have seemingly have money to spend - and are dead set on staying NA, I figure this would be the next best bang for buck (albeit a pricey one)
Spose the mental $$$$ figure ticking around in my head is also that of pulling the heads off & on myself too... be more pricey if done by a mech gents.
- Nacho
- SchumieFan
Well, putting different heads on can sometimes work, but you may spend more in finding if the compatibility is there... I'd hate to go buy a set of heads only to find they dont fit...
Increasing displacement is the other best bang for buck with the motor in peices. Done in 2 ways - first of which mentioned by Nacho - bore the block out. The process itself is not all that pricey, its then paying for ways of making pistons fit. Buying oversize ones or oversize rings depending on how big you go. I bored my mini out over 80 thou - we bored it so far, the 1 & 4 cylinders had to be 'offset' bored. Meaning they were bored outwards to the ends of the block rather than just enlarging the hole from a central axis. It took the motor from 1275cc (1.275 litre) to 1400cc (1.4 litre) Also hit a water gallery on no 1 piston & had to sleeve the bore....
The other method is to offset grind the crank small end journals - aka stroking. Ie the piston stoke will be longer, increasing compression. One of the V8 motors I built a few years ago was a stroker. All mighty torque but hampered in the high revs. Excess stroking may lead to requiring a cam profile change.
One of the favourite V8's I built was a 327 Chev motor. The 351 block (5.7 litre) with a 308 (5 litre) short stroke crank. Coupled with a stage 5 Heatseeker cam, it revved and pulled hard to 9500rpm. Love big bore short stroker combos
- SG
- SchumieFan
am i the only 1 who can see my posts? am i fuckin invisable? am i just jerking the chain? or am i beserk and insane?d_stroy_r wrote:A solution would be to put on the 2.5l galant mivenc engine head.
RPW do thse. Very expensive though.
yes, good idea, put a 6A13 Head on, forge the pistons, put a turbo on and upgrade your gearbox. dump pipes will also help.
- SG
- payaya
How about a cleaveland at 9600RPM??Bennoz wrote:Well, putting different heads on can sometimes work, but you may spend more in finding if the compatibility is there... I'd hate to go buy a set of heads only to find they dont fit...
