Have one in the wagon, as easy as the haltech to tune as well, I do recomend.
Still reckon you should keep it HKS Original
Yes, down at Wakefield, check out the NSW section for more info.d_dan wrote:Whats on the 22nd sept? track day?
It's thereabouts. And I'm not sure if it does it only high boost only, I'll have to give it a go on low too. but yeah, 1st and 2nd can be maxed out to 8k.Bennoz wrote:Is it exactly at 5.5k? Or thereabouts? If not, it sounds like gearbox mate. If an ECU can manage to mix air & fuel for it to go all the way to 8k in 1st, then there's no reason it wont do it in 3rd. Gear selection is irrelevant for it.
I reckon your torque converter is either not up to the challenge, or on its way out.
I know its a long shot, but why not try PM Jeff in QLD? He had a similar issue & had one made up to do the job. I dont reckon yours is anything other than a standard one & the car is making a bunch more power now that it used too I reckon....
Or HTFU and dump a 5 speed in there with a decent clutch.... it'd be f**ken cheaper...
Lol im joking thats what the advice most ppl are giving nowadaysAJ wrote: Fuel filter was changed less than 12 months go.
Ah ok, lol.silverGPX wrote:Lol im joking thats what the advice most ppl are giving nowadaysAJ wrote: Fuel filter was changed less than 12 months go.
I've not touched the 'box and you're right, I've not heard of anyone else taking a look either. Are you free on the weekend to take a look Dan? Or anyone?Astron_Boy wrote:only limitations I've come across when it's come to revs and power was fuel.
Having said that, there's no difference from 1st to 4th except for the speed, engine is still doing same amount of revs regardless if it was planted.
The fact that the car is stopping itself at 3rd, I think Ben to is about right on the money.
Think about all that cars gone through, history I don't think includes a gearbox...
Sorry, I may have missed, but has the auto been given a complete drain, including cooler, filter change and new 'mitsu' oil?
May cost you the good side of $100, however it may give a bit more insight and stop you spending any more beyond that.
If the oil is a bad color, then you know where the tc is heading.
